Restoration-Mini
Technical Forums => Maintenance and Modifications => Topic started by: ADRay on January 03, 2024, 09:49:52 AM
Title: HS4 Carb rebuild - correct ID
Post by: ADRay on January 03, 2024, 09:49:52 AM
I need to rebuild my HS4 carburetor (1982 with A+) but I'm not sure if I need the Waxstat jet or not. Is there an easy way to determine this? Thanks
Title: Re: HS4 Carb rebuild - correct ID
Post by: MiniDave on January 03, 2024, 10:14:13 AM
red jets are the waxstats IIRC, but I always convert them to the standard, it just works better and more consistently.
Edit: red jets can be either waxstat or not.....but again, I prefer the std jet..... makes tuning much easier.
Post by: ADRay on January 03, 2024, 01:09:20 PM
ah, so it's a choice?
Post by: MiniDave on January 03, 2024, 08:20:34 PM
Yes, if you have a waxstat now you have to modify the choke linkage a tiny bit, but it's very simple. Check YouTube for a vid on how to do it.....
Post by: ADRay on January 04, 2024, 07:08:29 AM
excellent, thanks Dave.
would this be what I would need for a full rebuild?
https://mossmotors.com/114-463-rebuild-kit
Post by: MPlayle on January 04, 2024, 09:25:36 AM
Even with overseas shipping and currency conversion it will be cheaper to order the same kit from Mini Spares:
https://www.minispares.com/product/Classic/Fuel/Carburetors/Repair_Kits/CRK219.aspx?130205&ReturnUrl=/shop/classic/Fuel/Carburetors/Repair~Kits.aspx|Back%20to%20shop (https://www.minispares.com/product/Classic/Fuel/Carburetors/Repair_Kits/CRK219.aspx?130205&ReturnUrl=/shop/classic/Fuel/Carburetors/Repair~Kits.aspx%7CBack%20to%20shop)
Using XE.com for the currency conversion, the Mini Spares kit prices out at about $81.50 (plus shipping) versus $139.00 (plus shipping).
Post by: MiniDave on January 04, 2024, 09:47:00 AM
I agree with Michael, but as they're out of stock at MiniSpares if you want to get it quickly Moss might be the right answer.
The same kit is available from Mini Mania (usually the last place I shop) for $100 plus shipping, just FYI   https://www.minimania.com/part/CSK52/Classic-Mini-Su-Hs4-1-1-2-Carburetor-Service-Kit (https://www.minimania.com/part/CSK52/Classic-Mini-Su-Hs4-1-1-2-Carburetor-Service-Kit)
MiniSport also has it in stock, about the same price as Moss and it also has the throttle shaft. If there's no play in the shaft I don't bother changing it or the throttle plate - those plates wear only on the edge, but I don't find that to be an issue. If there is play in the shaft you need to rebush it anyway, and that's a whole 'nother kettle of fish!
https://www.minisport.com/crk251-rebuild-kit-for-hs4-carb.html
Post by: ADRay on January 05, 2024, 06:04:34 AM
thanks gents. I usually use Mini Sport, but I couldn't find a the complete kit on their website.
