Restoration-Mini
Technical Forums => Maintenance and Modifications => Topic started by: towjoe on May 09, 2016, 07:23:51 AM
Title: Removing speedo cable
Post by: towjoe on May 09, 2016, 07:23:51 AM
Yesterday I pulled the carb and intake manifold in order to rebuild my HIF 44. Had to replace the speedo cable. I could reach the cable end but could not get it loose. Decided to try using my socket for removing the bosch 02 sensor. It worked. Just another way to remove stubborn speedo cable.
Regards
Title: Re: Removing speedo cable
Post by: Willie_B on May 09, 2016, 08:05:09 AM
This is good to know. Thanks
Post by: MiniDave on May 09, 2016, 08:08:59 AM
Is that the same as the O2 sensor? Cause I have one of those sockets too, never thought to try that. I made a crude tool instead....
(http://www.restorationmini.com/forum/index.php?action=dlattach;topic=832.0;attach=3345;image)
Post by: 94touring on May 09, 2016, 08:29:50 AM
Long reach angled needle nose work too.
Post by: John Gervais on May 09, 2016, 01:59:25 PM
I'm not sure I'm understanding this - what do you use your special tool for?
To remove the cable from the carb is easy enough, and then it's just a matter of getting on the ground with your head, shoulders and 2 arms in front of the seat, under the dash and reaching up to the retaining clip situated on the pedal's extension.
I use a short screwdriver to pop the clip (NAM6923) from the pedal, replacing it with a new clip upon re-assembly.
Post by: Willie_B on May 09, 2016, 02:15:47 PM
Quote from: John Gervais on May 09, 2016, 01:59:25 PM
He was removing the speedo cable from the transmission.
Post by: John Gervais on May 09, 2016, 02:21:57 PM
Oh yeah, so he was... crap - I really misread that one...    :-[
So, yeah, um, sure... what he said...   :-X
I think I'll mix another Pimm's and sit back for a bit...  Might even learn how to read...
