Please let me know if you have one for sale (or ideas where I could get one - have bought one from Ebay, but I need another)
Thanks!
How important is it the K&N style? I show everyone out including K&N themselves.
Otherwise any of these I show as a cross reference:
Fram ca2714
alco MD142
AP LK748
CLEAN MA365
COOPERS AG476
COOPERSFIAAM FL6330
FIAT 38242326
FIAT 39242326
FORD 5000505
FORD A730X9601H2A
Magneti Marelli 150010063300
MANN C1417
PUROLATOR MF748A
PUROLATOR MFP748A
ROVER 12G2373
SOGEFI FL6330
TEHO 2020
UFI 2772600
UNIPART GFE1038
AC-DELCO A1432R
AC-DELCO A1435R
AC-DELCO PC2605E
Thank you. As far as I can tell, all the cross references are more restrictive. I'm looking to open up air flow w/o any visual changes - so it has to fit within the current filter housing.
A Google search turned up this ebay Australia listing:
https://www.ebay.com/itm/183149162204 (https://www.ebay.com/itm/183149162204)
Hang on, I may have one......
nope, sorry....mine is an E-2601
Doesn't Vizard say the paper filters flow just as well? That's what I run on my green car.
Quote from: MPlayle on September 18, 2023, 06:05:08 PMA Google search turned up this ebay Australia listing:
Thanks, it's been for sale for a couple of months, but the shipping is a killer!
Quote from: MiniDave on September 18, 2023, 06:21:16 PMHang on, I may have one......
Yes they do, for the first 50 miles at least! Or here in dusty Colorado, more like 20 miles.
Jeggs might have them in stock. Doesn't say out of stock like everyone else anyway.
JEGS has it shipped directly from K&N. Since K&N is out, so will JEGS be out.
Quote from: MPlayle on September 19, 2023, 06:57:13 AMJEGS has it shipped directly from K&N. Since K&N is out, so will JEGS be out.
Yeah, I ordered in the hope they had some in stock. They took my money and did nothing with it, and just tell me "It's shipping next week" update every week. Shady.
Might want to reach out to KN. I see they have a custom make your own filter option. But also looking around more saw a couple places saying this filter is discontinued. If it is discontinued and they want an arm and a leg to custom make one for you, I would end up buying one of the cheap paper style as a foundation, using that rubber top and bottom and then use Uni custom foam sheets and create my own high flowing filter. Couple different ways you could do it.
For example this is for a VW. It would need to be cut down/modified to get your dimensions right, but it's pretty close as is.
Another idea after googling what you're working with, is strategically removing the paper, and/or trimming back, but leaving enough of them in place to keep the unit as a whole rigid, and then use a foam wrap on the outside.
Is it for a dual carb setup like the factory box example Dan attached?
If so, could you consider a single oval filter that encompasses both intakes rather than a separate filter per intake?
If it is a single filter box (like the original on an 850 with HS2 carb), possibly another filter with the same inner diameter and simmilar outer diameter and cut it shorter to fit?
I believe the top and bottom of the box has various indents that wouldn't provide a seal for one large filter. That pretty much requires having to use the tops and bottoms of the original filters. You could get pretty creative and use some aluminum plate and create a one piece top and bottom with cut-outs for the original rubber tops to attach, adhere, rivet, ect...however you want to do it. Then have one large custom filter that sandwiches in between the plates. Wouldn't be oval the whole way since the intake entry needs a clearance.
Would this 2601 fit? I know it's smaller than the 9001, but maybe better than the paper in your environment? I believe it's for a small block motor?
Quote from: MPlayle on September 19, 2023, 12:03:31 PMIs it for a dual carb setup like the factory box example Dan attached?
It is for an 850 HS2.
For some reason it sounded like duals. A single solution will be easier.
Well, the 2601 I have is for small blocks, let me know if you want it....it's brand new in the box.
I think the 9001 is for 1275's, esp the later ones with an HIF carb and air cleaner
The 9001 is meant for either the dual-filter box for twin carbs or the old style single HS2 air box for 850s. The 2601 is for the larger, single air box used on the 998s with a HS4 carb.
The first picture is the old, small air box for the 850s using the 9001. The second is the larger air boxes for the 998s using the 2601.
Could you get creative and make two from this one by cutting it in half and making a seal on the cut end?
https://www.knfilters.com/bm-0200-replacement-air-filter (https://www.knfilters.com/bm-0200-replacement-air-filter)
The outer diameter dimension matches the 9001. The inner is a bit larger and the height is a bit more than double that of the 9001.
I dunno, but this one I have is the smaller of the two sizes - it's about 4.5 ID and roughly 6 OD, so if that will fit the air box, he's set.
K&N lists the 9001 he needs/wants as: OD = 4.813" by ID = 2.125" by height = 1.750".
K&N lists the 2601 you have as: OD = 7.375" by ID = 6.125" by height = 2.188"
The BM-0200 I suggested cutting to height is: OD = 4.813" by ID = 3.125" by height = 4.500" This is the same OD as what he is trying to find. A slightly larger ID gives a bit of extra room around the carb throat that might conpensate for the different seal profile. With careful cutting, you could potentially get two of the desired height from one BM-0200.
If this is for a single carb on an 850, this 2601 is 4 1/2 ID X 6 OD X 2 high, so it should fit a stock air cleaner box perfectly. it's sealed, in a correctly marked box and I got it from MiniSpares.
http://www.minispares.com/product/Classic/Filters/Air/E2601.aspx?1201&ReturnUrl=/product/Classic/Filters/Air/MSF1008.aspx|Back%20to (http://www.minispares.com/product/Classic/Filters/Air/E2601.aspx?1201&ReturnUrl=/product/Classic/Filters/Air/MSF1008.aspx%7CBack%20to)
I don't need it so I'll make someone a good deal on it.
I have a new 9001 I was going to use but have not yet.
Quote from: Willie_B on September 20, 2023, 04:30:48 PMI have a new 9001 I was going to use but have not yet.
Do you want to sell it to me, or are you going to eventually use it? Thanks!
I can sell it to you. Let me figure out the price.
Looks like on Amazon they are listed for $60 and change. So hopefully they will be the same after they are back in stock. So how about $61 plus postage?
Quote from: Willie_B on September 23, 2023, 05:31:48 PMLooks like on Amazon they are listed for $60 and change. So hopefully they will be the same after they are back in stock. So how about $61 plus postage?
Very fair. PM sent for logistics.
Hi! Not sure my text to you saying "thank you" ever went through, and I have an update anyway based on actual road testing.
I've tested this air filter on both my Mokes. It makes a tiny bit of difference on my very stock 850. For the 850 with a bigger exhaust however, this air filter made a significant difference.
Thanks!!!!
Your welcome. Every bit helps with an 850.
