If anyone can explain how I can remove the bolt on this I would really appreciate it. I got the nut off but the bolt isnt moving and there isnt much room to work with.
Yeah you need a pickle fork/ball joint remover. Sometimes you can hammer them out, but you'll probably ruin the threads and compress it if its really on there. A lot of places rent the ball joint removers for 10 bucks.
I have the ball joint off already. I am talking about the large bolt that connects the arm to the subframe. Basically I am trying to replace my suspension cone. I have the strut/trumpet removed already but cannot get the cone out without removing the arm.
Oooo that bolt. I think I may have used another bolt and hammer to knock it out with. May have to get creative if there isn't enough room.
I seem to recall someone over on the Mini Mania forum describing the process in detail in a thread on that forum. I don't remember who. I want to say they described supporting the outer end of the arm so its own weight did not bind the bolt, then using a pry bar to catch under the edge of the head to work it out.
There is a plate on the front side that is held on by 2 nuts or bolts ( don't recall which). Item #25 in this page.
http://www.minimania.com/web/CatPage/8-9/Chapter/8/Page/9/Mini_Cooper_Catalog.cfm
