Weight results tomorrow.  I think the bag of lugnuts weigh more than a wheel.
10x6.  The American racer tires will fit perfectly.
What is the brown band around the middle?
The silicon beed that joins the two halves.  It's a 3 piece rim.  I can change out the center to different styles and colors.
It seals the halves so you can run tubeless
I was unsuccessful yesterday getting tires mounted.  Turns out these have a special valve stem that no one carries.  Force sent lug nuts but no valve stems, so a quick email later got the particulars on what is needed.  The UK version of race stems were rather expensive, like $50 for 4 valves.  I found some race valves off jegs for $28 shipped for a pack of 5.  Basically need a hole diameter just shy of 7.5mm.  Maybe next week...
Thousand dollar wheels don't include valve stems? And they require a special type too? sheesh
Gotta pay to play I guess. ::)
That would be my only gripe.  It would have been nice to include the valves or at least give me a heads up what size I need.  I wasted half a day trying to find a place that could do it.
Yea 10" wheels and special sized valve stems.  That's a tough find.  There is only one place on the north end of the Dallas metro area I found that can handle 10" tires/wheels.  If I remember I'll weigh mine when I get home cause they feel light.
My car has these really nice metal ones - I wonder where you get them?
The style I ordered is similar to that.  They are "high pressure metal clamp" style that fit a 7.5mm hole.  Most standard wheels are nearly twice the diameter hole.  I learned a lot about valve stems today lol.
Yeah, 7.5mm (less than 5/16") is really small, almost bicycle sized......probably weigh less too  ;D
Space invaders coil came in.  Here it is for size.
 Is it wrong I want to blast that with a laser?
Sharks with fricken laser beams on their fricken heads.
That coil would look so much better if you mounted where you couldn't see it!  ;D
So don't mount it on the bonnet as a hood ornament?
Well, if you are looking to make a theme car...
thebluepotato
Quote from: 94touring on October 18, 2018, 05:54:08 AM
I had same issue with my MB racing 3 piece rims....just found the right size on Amazon and they are stubby.  Just measure and get some off Amazon.  Also, make sure you CHECK all those hex nuts on your rims before mounting for correct torque before using.  Uber important.
