Smiths temp gauge calibration info
Started by 94touring, Today at 08:51:22 AM
I've never had to calibrate a gauge before but this week was the week.  I went through 3 different temp senders on hand, one for sure is supposed to work with the gauge. All read very high, one pegging out.  I knew there was a way to adjust them but had never done it. So here's the intel if you need to do it yourself.  I took a crap gauge apart to learn the internals before I accidentally broke a nice brand new gauge. Back side of the gauge has 2 spots with little slots.  They don't screw with a flat head but rather slide on a pivot.  Both adjust the readings. Doesn't take much to adjust it.
So what was the step-by-step procedure?
Well find a very small flat head to pry against the tab shown above to then slide it around till the gauge reads N around 180-190. I believe it ended up being an inward movement that brought it from reading abnormally high to normal. With the car running you can adjust it and it will instantly change.
