Rant of the Day - Sunroof
Started by MiniDave, October 29, 2025, 01:11:58 PM
So, I've owned a lot of German cars in particular, and while at the local MINI dealer yesterday asked if it was possible to order a car without a sunroof now, like I did with my 2009 Clubman S. The answer was sadly, no.
Not only do I have no use for a hole in the roof, I never open them, but I also hate the extra heat they bring into the car in summer. I'm not sure I notice the handling detriment of having the extra weight up there, but nonetheless, there is that factor too.
Audi, BMW(?) Mercedes - I don't think you can order a car without a sunroof anymore, or any highline car for that matter.
Here's my other issue. My 19K mile 2018 Audi Allroad is currently at the dealers, waiting on replacement sunroof drain tubes. Huh? you might say.....aren't they just pieces of tubing? Well, I assume so but my dealer insists that they can't clean them and that they must be replaced with factory Audi sunroof drain tubes - apparently they crack? Of course to even get to them requires removing the headliner.....a job I'm not keen to DIY.
One of ours is leaking, I found water back in the very rear compartment - my nose told me something was wrong as I started smelling mold when I got in the car that had been closed up for a few days, and then some electronical stuff started not working, leading me to that compartment in the left rear quarter of the car, full of water and expensive electronical parts. Since then while waiting for the tubes to come in (new and improved, and of course on back order now) the bride found a shorty car cover that only covers the top of the car, so it's easy to put on and off and that has managed to keep the important gubbins dry - but the smell remains even so.
The quote to replace the drain tubes is close to $2K, $200 of which is the tube itself, and they'll do both just in case and while they're in there. And of course they also found a few other things that I really should do.....replace the leaking motor mount (that's only $1000) and repair some corroded wires (back in the flooded compartment, I knew about those and I will DIY that) $1600 if they do it, and clean out the front drain tubes, those can be reached so that's only a $450 item. My total quote for today's efforts will be about $5K by the time you factor in shop supplies and $500 of tax.
All because of an option that I never wanted and never use.
Picture of what's in the previously flooded compartment...the tan connector with the broken wire is all corroded inside, and it's the one I'll be replacing - that little bit of plastic was $34 for both halves. Difficult to see but there is a fairly large and expensive computer body control module in there - it was under water. When I found it I dried it off and cleaned all the terminals with contact cleaner and it seems to be working still.....but I have a feeling I'll be getting one of those one day soon too.
#1
Doing some research, apparently this has been a problem on a number of Audis thru out their range, and they have done an extended warranty on Q3's for this exact problem. I see VW products have the same issue, based on the TSB's I found.....
So, when the parts come in I'll take it over and have them do it and save the tubes for me, then I'll send a sternly worded letter to Audi corporate and see what they'll do about refunding my $2K.
I'm concerned about the mildewy/moldy smell, even when completely dried out, if the car has been closed up for a few days it's really pronounced. I'll ask if they can spray any spots they find on the back of the headliner with something to treat it. I don't know if they'll do it or not, but that's another thing I'll be mentioning in my letter to Audi.
Unlike my 2017 (which does not have this issue - yet?) I did not get a complete service history with the 2018 car - the 2017 has had every service done by the dealer on the yearly basis rather than miles since the mileage is so low - 25K miles when I bought it last year. The 2018 car has no history in the Audi system, I don't know if they never did any or what....I know it was an extra car at their vacation home hence the low miles - only 15K when we bought it last summer.
We had water intrusion issues with our 92 100CS and our 2004 Allroad - the dealer did the factory authorized repairs on the 2004 sunroof leaks, but years later the issue reappeared. No issues in the 4 years we had the 2014 Allroad and no issues with the 2017.......
#2
That sounds annoying and costly.  And a reason to not buy another one.  Funny my 1994 Rx7 with sunroof doesn't leak and has never had an issue but new cars are total pieces of shit when it comes to parts breaking down after a few years.
Regarding heat through the roof.  Mine has a painted surface so sun doesn't come through.  I crack it open when the weather is nice and it gives a nice calm breeze.  Maybe you can paint yours if the glass creates heat.
scalpel_ninja
I was browsing the VW site checking out the new ID Buzz and decided to price out a Golf R too. They actually charge extra to delete the sunroof for their "Euro" option.
One of the main reasons I still love my daily R56 JCW, peeling paint and all, is because it doesn't have a sunroof.
I sure hate sunroofs too. There isn't literally no reason for them. They have not been, and never will be "enjoyable". If you want open air motoring get a genuine convertible.
My '02 Cooper S has dual sunroofs, one of which opens and one of which is fixed in place. I go through a once a year maintenance exercise to open the sunroof and then close it to make sure it is still functional and exercise the mechanical bits, but I never ever drive with it open.
When we bought my wife's Mazda CX—5 five years ago it could only be obtained equipped with sunroof. Of course we've never opened it and honestly, we forget it's there until the car has been parked in the hot summer sun, and you can feel the heat coming through the sunroof's shade.
And as long as I'm ranting on unwanted car features, I absolutely hate a powered hatchback. There is no reason to complicate that by adding a power liftgate feature. I have added padding to the inside of our garage door because I was certain at some point the damn liftgate would be accidentally engaged while the garage door was closed. Glad I did that because it did happen while a key fob was sitting in my pocket, the wrong button was pushed, and the liftgate started opening.
#5
I know what you mean, tho Rose likes the powered liftgate, and the under the bumper kick to open feature.
The Audi has one glass panel that moves and one that's fixed as well, and while it doesn't seem to get as hot as my 2003 MINI did with it's sunroof, I still don't need or want one.
I also take issue with so much tech in these new cars, and the fact that you really have no choice. I remember when I bought my first new Audi 5000 in 1978, it had a 4 speed manual gearbox, roll up windows and a wonderful cloth interior. It still had plenty of "luxury" features, like factory A/C (that really worked!) cruise control power 4 wheel disc brakes and power steering, but other than that it was pretty normal. I loved it! It was comfortable, rode and handled great, had tons of room inside and was quiet as a church on the hiway. It was light too, only weighed about 2500lbs IIRC.
It only had 100hp so it wasn't exactly quick, but it seemed plenty fast enough at the time, especially with the manual gearbox.
Ah the good old days.
I guess I got lucky when I bought my Subaru Crosstrek Wilderness a couple years ago - no sunroof.  It did not have the extra "bells & whistles" package that foisted a sunroof on you and I did not want that extra package.  Its rear hatch is also manual.  There are still lots of features I will likely never use, but at least it has an oil dipstick for checking the oil level without going through the crazy computer.
Brit_in_TX
Another vote for hating sunroofs.  All my cars have them, and they never get used.  The Hondas they are standard and you cannot have them without.  The GMC can have them removed (and you get a small credit back), however I bought mine when it was 18 months old and it was already spec'd with it.
Another thing I hate is leather interiors in cars.  Especially in Texas they get too hot, and I had a rental the other day and it had a "pleather" and that was even worse. At what point was it decided that fabric interiors were no longer acceptable in well spec'd cars?
#8
Agreed....note my comment about my 78 Audi 5000 - it was considered at least on the same level as Mercedes and BMW at the time, and almost all of them had cloth interiors - leather was an expensive option that only a small percentage took. Mercedes and BMW mostly used vinyl. The cloth in my Audi seemed to wear well too....and the other wonderful thing was they came in colors! copper red, green, light blue, tan, grey, gold....I mean.....wouldn't that be nice again?
I suppose you can still spec American made cars the way you want them? I don't mean poverty spec or salesman's spec where you didn't even have power steering or brakes, but at least you can de-option a bunch of un-needed crap?
The first Lexus LS400's could be bought without a sunroof and with cloth interior, they soon changed that and leather and sunroof became mandatory about 6 months after they first went on sale.
Going slightly off topic here, I'm impressed with the interiors on the new MINIs, they've gone to a woven bamboo fabric on the dash and door caps, and the fun thing is there are big enough pores in it that they run LEDs behind the fabric that can change patterns and colors. They also offer a white interior this year! One thing that always bothered me were the dreary dark interiors......
scalpel_ninja
When I leased my Subaru Ascent, it was ordered from the factory with everything I wanted and nothing I didn't. When I told the salesperson who was writing down the specs, he looked at me funny when I said I didn't want a sunroof and didn't want navigation (part of the same multi-thousand dollar package). He also questioned me when I opted for a bench second row (8 seats) and not captain's chairs (7 seats). I looked at him and said: "I never use the sunroof, it's extra weight, something extra to break, stock navigation is almost never good, and why am I paying more money for less seating?"
Yep, we have factory Nav in both our Audis and of course at 7/8 years old it's out of date. While I'm spending boucoup de bux at the dealer I'm going to ask how much it would cost to update the maps............ paramedics will be on standby!
Rose found an obscure note that if they've never been updated from new Audi will do it one time for the new owner.....I'll be printing that out and taking it with me cause even tho I'm on great terms with the service dept (used to be my next door neighbor till he got married and moved around the block) I'm confident they'll claim they never heard of such a thing.
scalpel_ninja
Quote from: MiniDave on October 30, 2025, 12:31:25 PMYep, we have factory Nav in both our Audis and of course at 7/8 years old it's out of date. While I'm spending boucoup de bux at the dealer I'm going to ask how much it would cost to update the maps............ paramedics will be on standby!
First car I owned that had a nav was a 2004 Acura TL. It was one of the few decent ones with touch screen entry. To update it, it was as simple as buying a new DVD with the new maps, ejecting the old DVD in the trunk mounted unit, and inserting the new one; no traffic data though...
Yeah, nowadays it's all part of the infotainment section - in Audi speak the MMI, Multi Media Information. There are rumored pirated version available, but I think I would pass on that.
This one works really well, you just tell it where you want to go and it pops right up on the screen. It also has a neat little function, that as you get close to your next turn it pops up a smaller version in the speedo showing you where to go, what lane to be in etc and it has a bar graph that counts down as you get close to the next move. Once thru that it goes back to the main screen. Works a treat!
The phone integration is really good too, you just tell it to "call whoever" and it handles it, don't need to look at the screen or poke something for it to work. One of the easiest to use I've ever come across, once you learn it and get it set up. When you pair your phone it automatically loads in all your contacts. You can even have it read emails and texts to you, and you can dictate a reply, but I don't bother with that .....
Dan Moffet
We recently bought a 2019 Honda HRV Touring, complete with Nagivation. Haven't used it yet, but did look up to see about how to update the map. Honda provided map updates for 5 years (S.O.L.) but then says the map update can be purchased directly from Garmin. Down load to a USB stick, plug it into the mystery car system (we have a LOT to learn) and follow the instructions to get the map in.
I don't plan on doing it any time soon. We'd use the Nav system less than the sunroof!
Back to the Audi drain issue, Ya gotta wonder about engineers that would put any kind of wiring connections anywhere near a drain tube, not to mention a computer unit.
Maybe it is planned obsolescence in a digital age: Car bodies rust less and are mostly plastic where rust occurs. Engines and transmissions are much more durable and efficient. Put the electronics under a water source and design the water management (the tube, a cheap part) to fail predicable. Presto!
And we thought the Mini's 4-fuse fusebox was prone to moisture problems.
#14
That's not quite what happened on the leak.....apparently it cracks or breaks at the joint where the tube attaches to the sunroof cassette, then the water instead of going down the tube, follows the headliner and body lines down to the well in the back...at least that's what they're telling me.
I will be heavily involved when they do the repairs - I want to see the broken tubes and I want to see if there's mold or mildew on the inside of the headliner.
One of the things I like about this shop (and it protects them too I suppose) is that they video their work and email it to you.
Except......the young guy did a "courtesy inspection" where they check all the tires, brakes and look for leaks under the car. He video'd the tire wear for me ( all the tires have plenty of tread), but didn't say a word about the two that have date codes from 2018 and are weather checked!
I'll be curious to see if they do it again when it goes back for the leak repairs as I'm going to swap over the two tires with 2021 date codes from the other car and put 4 new tires on that one. That way the silver car will have 4 "good" tires since that car gets very little yearly milage and the white one that we put the most miles on will get new shoes. He also mentions a leaking motor mount, you can't even feel the engine running in this car so I think I'll let that go for a while, they quoted just over $1K to replace that! He also mentions the corroded wires, I'll fix that before it goes back.....Here's the video of the inspection....
http://asmks.mkvwa3.com/p/f4Pl9X.html
ve9aa
I didn't read every post (yet) but wanted to add:
I HATE sunroof's (I don't like the sunlight from overhead (11am-1pm or whatever) shining in behind your sunglasses. That sucks. Noise on the highway sux too!
Worse are water leaks.
Our 2012 BINI Copper suffered from this and water got down into the footwell module and wreaked havoc with a lot of electrical systems.
What a Royal PITA ! ! !
Mike in NB
That's what happened with our 92 100CS, only I have to say it wasn't the car's fault - the dealer left the damn sunroof open, lost the keys to the car and it sat outside during a huge downpour. All the computers were under the passenger floorboard/kick panel and there was 2-3" of water in the floors.....Insurance totaled it.
It's also why I ordered my MINI without a sunroof!
