Mini ST Hotrod
KimB and 3 Guests are viewing this topic.
So, there's been a bit of a delay......I've spent most of the last three months flat on my back in bed with back problems. Two different trips to the ER (which are basically a waste of time as all they can do is give you heavy drugs to try and blunt the pain) and finally got in to a "pain doc, who gave me an epidural - which to my surprise (I had one in 2019 for similar issues, and it worked) had little to no effect. After a week I called and they said it could take up to two full weeks for it to give any relief!
Right at the end of the two week period it began to get better, but I got another appt and they doubled down. This one seems to have done the trick tho they cautioned me "no lifting over 10lb" and "take it real easy for the next two more weeks. If this doesn't do it I can't have another till Mid Nov, and I may wind up being a candidate for surgery anyway.
So needless to say all I've been doing all summer is watching TV....
Today I went back to the shop and tore down a friend's Mini gearbox so he can order parts. This is a very nice looking car but I think the maintenance has been sorely neglected. There was a surprising amount of sludge in the bottom of the gearbox, and 1st and 2nd gear synchros were wiped out, and teeth broken off of the gears too.
So he's got a list in to Spares and when those arrive we'll put it back together.
The hot rod is back on the rack and ready for more welding. My friend Zac acquired a nice set of 13X7 wheels and we tried one on and it fits perfectly, I traded him my rear swaybar for a pair so I now have my rear wheels sorted. Fronts will be matching 13X6. So it looks like the Sport Pak flares will work.
I also did some more trading, the WRX seats I ran for a while will not fit with the door beams in place, so rather than remake those I sold the seats. The leather seats that Dan gave me are very comfy and will fit, so that's one choice still available.
Those wheels fit just right.
They look good.  Sucks you've been out with back issues so long. No fun at all.
#253
I think they're going to work perfectly, just need to figure out what to do for tars....
Without the left side flare I can't check for sure but it looks like the frame is shifted about 1/4" to the right, but it's also up against the body, so it's probably just the fine quality of the MiniTec frame, or the Mini body!  :grin:
Either way, all I'll need to do is use a 1/4" spacer to get it to match up.
The best part about these wheels is that they don't hit the trailing arm, the offset is better. I had to put a 3/4" spacer behind the other ones to keep them off the trailing arms. Of course the alignment isn't set and the hubs aren't tight without the axle shafts bolted in place. Still, another piece of the puzzle in place now.
I'm starting PT for my back today, and the doc encouraged me to join up with the local community center - which has indoor pools - and start swimming, so I'll do that too.
Red Riley
Dave, I bought a set of 175/50-13 Grip Max MaxGrip Classic tires from Priority Tire for 60ish bucks each. Actually I ordered them while I was in Asheville at MME, when they got them in stock. Just checked and they still have some. Tiremart.com has them too. If you can find Nankang AS1 in that size, they are good too, for not a lot of dough. I've been running the Nankangs for about ten years on my Elf and I think they are better than Yokos. Not got the MaxGrips mounted yet, but they look decent.
#255
Right now the plan is for a set of Toyo Proxxs, super sticky. Putting 250hp thru 13" wheels I think I will need it!
For now the tires on the wheels are older but not weather cracked, so they'll do for the early test running and such. I'll be curious to hear what you think of the GripMax tires.
#256
Yesterday I picked up the mate to the black leather seat from Dan, it was a bit moldy from sitting so long, but a sponge and some Lysol spray took it right off, then I soaked it down with some leather conditioner.
Once I can get some help I need to lift it into the hot rod and see how it fits with the door beams in place. Seemed like the right side fit ok, so I'm hopeful they'll both work. BTW, if someone can identify what car these came out of I'd appreciate it - BMW? VW? I don't think they're from anything American or Japanese....I can tell you that they're pretty comfy to sit in, and they even have lumbar adjustment.....all manual, no electrics.
I also got the rest of the Sports Pak arches....it's curious - this car had a set from the factory, and the right side rear arch holes lined up perfectly. However, the left side doesn't even come close, so I'll need to drill some new holes at some point. Just setting it in place to check how the other wheel fits and I'm happy with the look. Next I'll go ahead and build up the front end and see how those fit, whether I'm going to run 6" wheels or use the other half of this 7" wide set.
I also need to remove the springs from the rear shock then re-install them so I can move the wheels all the way up to the end of their vertical suspension travel, I may need to trim al little out of the inside of the arch for tire clearance.
The front fenders have been replaced so I'll need to figure out where those holes go and drill them from scratch.
And Justin got wheels and an exhaust and Zach gets a not as rusty shell if he wants it.  Free mini parts giveaway week.
#259
Well, the only way these leather seats will fit is if I remake the side bars, those bars are just too big and won't allow the seats to sit flat where they need to be. So, options are to use something else or remake those side bars. Now that I think about it, the only seats I haven't tried are the ones that came in the car from the factory - I've been running those in the green Mini, they're very comfy too! I do know that early Miata seats will fit with the big side bars, but any of those I find will need to be recovered. I think these nice leather seats will be more comfortable, but re-engineering those sidebars to allow them to fit will be a job. First I need to finish welding up all the bad metal on the left side and all the remaining bits on the right side that I skipped for now. That will probably take another month and we'll start having cold weather again.
I think I'll go ahead and build the front subframe too - it has to be done at some point, and that way I can have it on wheels so I can move it off the rack if I need to work on the red or green Mini/MINI. I can go ahead and install the rear calipers and start engineering the handbrake too. I was just going to use a linelock (might still) but the new Miata rear calipers came with the em. brake hardware, so I'll look at whether I can do that or not.
SO many things left to engineer and build!
#260
I took the floor brace out and as expected the worst rust was under it, just like on the right side. I'll butt the rear section I have up against the front and weld it all up, then make a filler patch for the back edge. But first I'll need to remove the upper and front parts of the roll cage to get it out of the way, then once the floors are all done I'll need to make a new cross brace - my plan is to make it smaller in cross section but out of stronger material, maybe 18 gauge. and I may make 2 - one that goes across in front of the seat attachment and one under the seats......not sure on that yet.
