Tig Welders
Started by MiniDave, April 03, 2023, 03:10:25 PM
#25
OK, spent some time with the new welder - I think once I get the setup nailed it should be terrific.
To that end today I got the gas plumbed up and installed the 10lb spool of .23 wire, then I tried to run it thru the torch and it would not drive. spent some time scratching my head, then I pulled the drive wheel out and saw that the grooves in it were either for flux core or .35 wire. I dug around for a while till I found the alternate drive wheel that came with it and could see that not only were the grooves not as deep, they were knurled! so, fitted that wheel and it moved smoothly once I got the tension set right and sure enough, it drove the wire smoothly till it came out the end of the torch. I switched over to the .23 tip and set up to run my first welds.
I started by just making some dots, since most of what I'll do will be plug welds.
But first - I watched some more "You Tube Welding Academy" videos on setup - this thing is wildly different that anything I've used before in the variety of setup options there are besides just wire speed and amp - in fact once you set the thickness of metal you're welding and the size of wire it will automatically set the wire speed and amps for you. The issue for me was learning what the metric equivalent was to the thickness of the metal I'm using, so I could pick the right numbers. I'll make a small chart to tape to the inside of the door with those baseline numbers on it to save some time on setup in the future.
So I did about 5 or 6 dots on the factory setting, then I added a little more power just to see the results, then I added some inductance to see if I could see any difference there....I think I'm going to have to burn a lot of wire before I can see the subtle differences these adjustments make, but for now I think I'm ready to melt some metal together.
More as it happens. One thing I've learned, I built my little welding cart so it would fit under my bench, but I have to get clear down on the ground to see the buttons and dials on this welder so I can set it and that is hard for me to do. So I may wind up buying a more modern cart that moves the welder up to like waist height....we'll see. The problem there is where the heck do I put it?
A pic of my efforts today.
#27
Getting there. I think now that I've been using it a bit I'll probably go ahead and sell the old one, just so I have more room in the shop. It's worked extremely well for all these years, the only issue I've had is finding consumables for it but I'm well stocked up now.
It's the perfect welder for someone who wants to learn to weld as it will run flux core or gas as long as you buy the gauges and rent a bottle of gas - worth it IMHO for the cleaner welds.
It won't bring much money as there are scads of welders on FB and Craigslist for really cheap, most of those are small stick welders or flux core only and most of them are so dirty - I mean, you couldn't take a shop rag and wipe it down once in a while?
Edit: found silicon bronze wire - from the local welding shop it's only available in 10lb spools for $200, online I found a 2lb spool for $42 but I think I'll leave that be for now. I also need to see about getting the tig torch set up and I'll need to buy some welding rod for that, plus I'll have to change out the gas bottle for straight argon. I still have a lot of mig mix left in my bottle so maybe that can wait too.
Pretty sure my welding cart came from HF. I've had it ages and still rolls around.  I saw vevor has good deals on wire spools.
I'm sure one of theirs would work just fine, like I said the only problem is where do I put it since it won't fit under the bench anymore. Need to give that some thought before I run out and buy one.
Would something like a Harbor Freight "lifting cart" work?
Lower it to fit under the bench for storage, raise it when using for reaching/reading the controls?
#31
I have one of those, but it's usually in use......plus no place to attach the gas bottle. also, the handle is too tall to fit under the bench - while it is removable, it would be a PITA to do that every time I used it. For now I think I'll just use what I have.
#32
OK, well this has been an interesting journey with the new welder. I'm used to having two dials, one for "heat" and one for wire speed that you adjust to get your perfect weld. This one has all electronic displays and one knob. As you cycle thru the various parameters you use the one knob to adjust those. There is no speed control, that's done by the computer based on the other settings you choose.
First setting is the amps, second is the voltage, third is the inductance. You also have to choose your wire size, gas type and so on. Once set the machine is supposed to do the rest.
I've used Mig mix - 75% Argon 25% Co2 - for my entire mig welding career - some 40+ years now, but I read several places that said for welding thin sheet metal such as car bodies, straight argon is better, so when this bottle ran out I switched over a few days ago. It has not gone well....
So today I'm going to do several things to try and figure out why I'm having so much trouble - which includes poor penetration while blowing holes in the metal at the same time! First I'm going back thru the settings - I managed to find a chart that gives the base settings for what I'm doing, tho it's pretty incomplete. I'll set it up according to those and see what it does. If that doesn't give good results I'll hook up my old welder and see what it does with the same bottle of gas. Depending on how that goes I may wind up taking this bottle back and buying another bottle of Mig Mix. It was welding OK on that, not perfect but OK.
I'm sure it's more a matter of me not understanding how it works rather than a machine that doesn't work correctly....it does weld, and some of my welds have been really nice (on Mig mix). Seems obvious that the gas is most of the problem here, but according to what I've read, it should work better - and this machine has a setting specifically for this type of gas.....
Still learning.....which is always a good thing.
I still haven't found a cart solution, but I think I'm just going to go buy (well, order - no one has anything in stock that you can just buy these days! but that's a whole 'nother rant!) a cart and be done with it. I modified my old cart to fit this welder and it works OK, but getting it up higher would really help, plus  too and also these new carts have drawers for your extra cables and such and a cabinet to store your helmet inside.
#33
Probably 99.9% of the time its c25 like you said. I have seen people sometimes use 90/10 argon/co2 for thin sheet metal mig but generally 100% argon is for tig.
Of course that's just what I have seen and I am certainly not a professional or anything so I could be way off base.
Your penetration issue makes some sense, though. The more argon and less co2 the less penetration you get.
This is what the internet says. I use 75/25 on thin sheet without any issues. 20 gauge is pretty easy to burn holes through if you're heavy on the trigger.
#35
Well, my experiment is over.....try as I might I could NOT get the straight argon mix to weld well. Today I was making a tool for Don for his GT6 to change the guibos in the rear axle shafts and no matter how much I played with the settings I could not get a good weld or any penetration. So, I took the practically full bottle of Argon back and got a regular 75/25 mig mix like I've been using for 30+ years. Since I already had the bottle out I put it in my old welder cause I knew how to set it up, plus I had .030 wire in it instead of .023'
Took a little  bit of fiddling but before you know it I had good solid welds with proper penetration and pretty nice beads. I was welding 1/4" metal onto 1" metal, which is a bit much for a 120V welder setup, but it burned in nicely. The tool turned out fine, so now he can change out the old cheap ones (lasted all of 2K miles) and put in proper $300 ea Metalastic ones.
I haven't given up on the new welder, I just need to learn how to set it up properly.
