73 Mini Innocenti 1300 Export
Must have had some Australian guy working at the factory putting in his little touch.
More parts.....I've been waiting for the valves to come from MiniSpares - I thought I would have them Monday, but here we are Thursday - they're supposed to be here today but nothing yet.
I also finalized the Newton Commercial order for the new seat covers, they took the original order no problem, but they wanted me to pay for the shipping separately. They claimed they sent me a link to pay it but I never got it, so I sent them an email, they said send my CC info in an email, I said no so then they finally managed to send a link to the balance, I paid it today so now they should be one the way too. It was expensive shipping - £270. That took two weeks too!
Lastly, my Garmin that I use for a speedo in my Green Mini died, (it was 5 or 6 years old) so I tried to order a new one from Amazon. My account had not been used for over two years (because I couldn't get it to open)  so I called customer service. The reason I could not use it even tho I had the sign on and password was that they wanted to send me an email to verify it was really me - perfectly fine idea except......since I had opened the account I had changed email addresses and the one set up with the account did not exist anymore - so they could not verify and I couldn't get into the account to change the email address. Round and round we went. Finally in frustration I opened a new account and ordered the Garmin......but now I have no access to my previous order history. PITA.
Yea I went through the same thing with Newton.  Luckily my link worked, of course there was little communication from them on my order.  After a couple of weeks I emailed and asked the status and one of the things was being made and as soon as it was done it would all ship.
#453
Parts from England made it about noon Friday, so I ran them downtown to the Cylinder head guy, he said it would be done "sometime next week". Since I was out and about I drove further north to drop by the crankshaft guy. They had not touched it yet, but promised me it would be done "sometime next week" too.
The crankshaft place had a sign at the desk claiming that wait time for engine work was as much as 10-12 weeks out! So if I do get I next week it will have only been three weeks! I guess I should feel lucky......
While not as bad as last week my back is still hurting, but I got tired of sitting on the couch and there's nothing on TV so I went down to the shop and cleaned a few bits in the solvent tank and swapped the shaft and rocker arms for the new forged ones we got.
A couple of things to note, even the *new improved* rocker arm shafts are not expensive and the wear patterns on our old one show why you always change it.
Also in the second pic you can see the wear patterns on the tips of the old rockers - note that they're offset. They are supposed to be that way, the idea is that they hit the end of the valve stem just slightly off center, which causes the valve to rotate a tiny bit each time it opens and closes, this is to make sure you get even wear and heat/cooling on the valves.
In the last pic with the new rockers you can see that a couple of them are offset just a bit, that's because the stands are not placed exactly central to the valves - I won't know for sure which one will end up where till I get the head back and set the rocker assembly on the head. It's fairly simple to slide them off and on again but a bit fiddly. Another thing you have to watch for is that the push rods don't hit the sides of the holes they go thru, this might require yet another rejigging of the rockers on the shaft.
Once the crankshaft gets back from the shop I'll install it and one rod/piston with no rings, then I can dial in the cam without the drag of all 4 pistons/rings. To get all of the measurements set up correctly I'll have the crank in and out a couple of times.
It takes a while to build one of these correctly, but the finished product is worth the extra time to get maximum performance, economy and life out of the engine.
#454
One other small project I whipped up this afternoon.....
To set the timing on these early cars there's a small window on the bellhousing that you look thru to see the timing marks, back in the days of the 850 it was easy to see in there, but on later cars, especially those with a brake servo mounted over the bell housing, about the only way you can see the marks is with a mirror....it's dicey at best.
So, I made a small bracket, and once I have the crank in place and I've used a dial indicator to find TDC, I'll make a corresponding mark on the front pulley ( this pulley is from another - later - engine) to match the pointer. Then I'll have TDC, and with my fancy schmancy timing light I can easily set it to whatever I need just by using the TDC pointer and the adjustable scale knob on the timing light.
Quote from: MiniDave on April 18, 2019, 08:45:03 AM
Weird thing is, the rears also have the two small holes drilled in the gutter!  8.gif
My 70's New Zealand Mini just had holes with no cut outs, two at the rear on each side and one on the front on each side.
One on MM for sale page today. Missing some of the Inno bits that you guys are making sure to include.
https://www.minimania.com/cars4Sale/15300/1973_Morris_Mini_Innocenti_Sedan
I've seen that one for sale for quite a while now, wonder why it hasn't sold? Seems like a really nice build to me......
#458
Cylinder head came back, looks nice.....I taped it off and gave it the first coat of POR 15. Once the crank comes back "sometime this week" then I can start building the engine.
amanley
Can I say, I'm really looking forward to seeing this thing come together! Good job guys.
1978 BL mini 1000
2005 MINI Cooper S JCW
2013 MINI Countryman All4
Cylinder head going together......
I have had an acquaintance ask about checking the VIN of an Inno Mini.
I know the VIN on an Inno is stamped/tagged differently than regular Minis with a prefix stamped directly into body metal somewhere - usually a prefix is something like B38/??
Can Dan post a picture of the location(s) of the stamped prefix and any tag(s) from this Inno as a reference point I can pass along?
Thanks.
#462
Nope, we believe this is a reshell....so there is no vin stamped in the body that we've been able to find.
However, it should be stamped on the inside of the right fender in fairly large letters/numbers.
We did find a matching vin (to our title) on our window glass tho...
But that's only on these later models, I'm not sure about the earlier cars.
Mk1/2 started with B39/1
Mk3 B39/2
Export 1300 B39/7
Will mount doors tomorrow, color sand and buff.
#465
Excellent!  Now I need to put it back together.....
Looking good, love that boot lid indentation.  Dave do you have space to put it back together.
Well, I'll have to move a few things around, but the good part is I have more and more room as I put stuff back together. Right now the lift is serving as a table for storage and a workbench for the motor. Once that's back together I'll clear off the lift as the engine will go back into the test stand till it's ready to go into the car.
New mirrors on.  Look pretty nice too!
Vikram
 Looks really good! Where does one find VIN on the glass?
#472
Right front lower corner of the windshield on this car.....DGM37060 model number, not vin, sorry.
That symbol of a heart shape with a "S" in it means British Standards so that is piece of UK glass, not an Italian one. Likely got changed out during the car's time in England.
On innos the dgm number followed the vin.  For example b39/7 54000 dgm12345
