Merlin
Spray foam installed today. Paint tomorrow.
Engineering the Impossible
The R53 is showing signs of failing suspension at 55K miles.  I just ordered close to 2K in suspension upgrades for the wives car.
The coil overs with camber plated for the front arrived in 24 hours, the rear camber links and front strut brace are on backorder.
After a phone conservation with Way, her highly recommended the spring / shock Combo I ordered. Thanksgiving weekend is going to be eventful.
Made a torque break away setup for testing clutch holding force on VWs.  This one comes in at 210ft lbs. Thanksgiving project.  Click to rotate.
Cool, I wonder how much it changes after a little break in? Also, I always wondered how much difference changing the step height in the flywheel can make. In the past, I ground a lot of flywheels, and we would get customers requesting custom step heights, usually tighter. When I asked them, the answer was normally to get quicker engagement and more holding power, but they never really said how much.
I tried various shims on the pressure plate to see if it would add or reduce clamping force. A 0.030 shim gave the best results by about 10ft lbs. I will probably need a stage 2 pressure plate however for what the engine will be producing that it's going on, and then factoring in some natural losses from the pressure plate over time as it loses a bit of it's strength.
#1080
I've got enough motors to build for VWs that this really helps take the guesswork out of what the clutch can handle.  Once you start getting into the higher end builds you really have to pay attention to the clamping forces. I don't want to overcompensate with some 4 puck race disc on a stage 3 pressure plate, but I also don't want to have to pull it after 3 years of use because it starts slipping.  This stage 1 is a 1700lb pressure plate and I bumped up to a street friendly dual friction disc from a heavy duty organic that I have been using on a much milder engine.  I don't have any heavy duty organic disc laying around to compare to the dual friction as far as gains go but will be interesting to see whenever I'm able to do that test. Online people say 160-180ft lbs.  I'll be on the ragged edge at 200ft lbs so a stage 2 at 2100lbs is on the way to see what it gives.  I have a longer clutch arm so hopefully the pedal isn't a total leg killer.  The stage 1 isn't bad at all.
I have used VH44 remote brake boosters on a hydraulic clutch setup to deal with pedal effort issues. It's a lot of messing around, but man, it's sweet if you end up needing to do something.
