Red Riley
Quote from: MiniDave on December 12, 2020, 02:53:36 PM
That looks like pretty small rebar - did you heat it to bend it?
Yeah, it's the little 3/8" stuff. It didn't need any heat. I just clamped it in the vise and beat into submission with a hammer. The hardest part was getting it to bend at 90 degrees to the seam so it would have a consistent face to grind flat on the back. I ground off the seam and notched it with a file where I wanted it to bend before whacking it with the hammer. Took a couple of tries to get it right.
I can't see any pictures of the buckle is it just me?
While the engine is still out I replaced the wiper system. Cleaned and regreased the wiper motor a while back. I did the system then but have not been happy with how it has not been going smoothly. It is all 45 years old so time for new stuff. Have to cut the drive cable as it is WAY too long. Then decide what to lube it with. I used general purpose grease last time and I think it is too thick.
The engine should be ready for me to pick it up at the trucking terminal on Monday the 21st.
Quote from: Willie_B on December 20, 2020, 11:47:55 AM
I used cv joint grease in my 60 wiper system still working great even when really cold.
I find those wheelboxes get stiff over time - sometimes you can free them up with some penetrating spray, but it's probably a short lived repair.
I use red axle grease to lube the cables, seems to work even in the cold - tho I have to say I really don't use them often in really cold weather.
Good to get some of these sub-systems working well for the coming driving season.
did you have to grind the tab off that little fitting that goes in the end of the wiper motor?
Quote from: MiniDave on December 20, 2020, 01:48:41 PM
The new one looks just like the old one. The wiper motor is completely apart and soaking in cleaner so I have not tried to fit it yet. You know how I am. If it is out I will take it apart to clean and make it look nice.
Certainly the time to do it.  I cleaned and regreased mine when I had the car apart. I just used regular bearing grease. Seems to be fine.
I find that old grease turns waxy and doesn't lube well.
Thought i posted some pictures about repairing  a grande piano but don't see the post. Tried posting four times on facebook but they never showed up so I gave up posting.
Quote from: tsumini on December 21, 2020, 10:33:22 PM
Is it giving you an error?
I noticed a long while back that the SMF forums will not show a post that is just pictures.  You have to start with at least some text, then the post will show up.
Without any text, it would appear to work (no error), but the post would not show up.
Could that have been the problem?
#590
I hung the 998 Automatic off the engine hoist in the driveway, fired up the pressure washer and gave it (and my self) a good blasting.... but first I sprayed it down with some engine degreaser - which stinks even now after washing it off thoroughly. The whole garage smells of this stuff even tho I washed it outside and blew it off with air before bringing it back in.... I don't think I'll ever be tempted to use it again. It was the Autozone house brand engine degreaser.....nasty smelling stuff tho it seemed to work pretty good.
This poor 998 had been sitting on a dirt floor for 10 years or so? Anyway, the bottom was caked in mud and the upper parts were grease infested, I think it came out pretty good actually, I didn't get every spot of dirt off of it, but it's WAY better than it was!.
Next I need to strip the trans off the engine and box it up to ship to Boot2Bonnet for a rebuild.
I have a small pallet the YRC driver gave me when he picked up WillieB's engine the other day, but I'll need to go down to HD and get a 2X4 and some 3/4" plywood to make up the box.
Quote from: 94touring on December 21, 2020, 10:37:25 PM
No error it just didn't show up. I'm thinking now that my keyboard suddenly shifts back a few words so I end up with misplaced text. I have had a couple of instances of disappearing text like I selected all and hit delete. I'll try to repost when I finish the job.
Red Riley
#592
I wanted a tongue jack for my little half-Elf trailer. I did some google searching and found this universal swing arm mount moped kickstand.
I made a couple of little mods to it and bolted it on. Works great.
Great idea and follow through. The extra foot area tucks nicely out of the way when up.
I finally found some ambition to go out to the garages and do some needed maintenance on Ms. Ruby.
I replaced all the tail light bulbs and front turn signal bulbs with LED replacements.  I cleaned the tail light housings and lenses while at it.  The flasher for the hazards works fine with the new LED bulbs, but I need a different one for the turn signals.
I also greased the rear suspension, replaced the fuel filler to body seal, and replaced the rear windscreen seal.
Next up is getting a replacement flasher relay for the turn signals, greasing the front suspension, and an oil/filter change.
Are you happy with the brightness of the new LED lights?
They are definitely brighter than what I started with.  I did one side then compared the amber of the hazards and the red of the running lights between the old and new.  The only comparison I could not do was the differences in running versus brake lights.  (It is hard to see the tail lights at the same time as stepping on the brake pedal.)
Well, after you and two others commented on my "dim" tail lights on the last group drive ...
It was time to step up and make the change.
After two trips to the parts store, a few hours of totally dismantling the dash, and lots of contortions later, I have the new LED turn signals all properly working.
The first parts trip was to get a 3-prong LED compatible flasher per the nearest wiring diagram for a RSP Cooper.
Then after the first round of contortions and total dash disassembly, I finally found the turn signal flasher in a bracket hidden behind the instrument cluster and it turned out to be another 2-prong unit.
Second trip to swap the 3-prong for a LED compatible 2-prong unit.
Got it swapped and tested as working nicely, then another round of contortions to put the dash all back together.
