Don's Vtec Pup
Started by MiniDave, June 19, 2018, 04:30:52 PM
Bahowe1
Dave,
You guys are amazingly fast!  It's gotten busy for me with a couple international work trips, but I thought I still had time to respond... so much for that! (not that I would have been able to provide you any help)  Well done sir.
I think he'll really like the taller final drive, but he will probably just go that much faster to where he is at the same RPMs.  --Sorta what I do.
So why did the clutch wear like that?
#52
I think it was the original clutch,, so it has 170K on it, not too bad then, right?
We do have one electrical connector we're puzzling over, it's got three connectins and the body is square or rectangular - we haven't found where it goes yet......we have all the connectors accounted for other than this one. Looking at old pics from when it was new, it appears to come out with the main harness and go straight down the back of the engine - to where we haven't quite puzzled out.
It's the one laying on the valve cover in this pic.....
Could it go down the back to the transmission - speed sensor connection for ECU or speedometer?
Possible, but he already has one connected there......and I think it had more than three wires in it. But it does seem to go to that area.....we thought it might be for the O2 sensor, but that one has 4 wires and again he already has one connected there.
We have yet to find an open, unconnected place to land it.......
Well, the other thing is to trace back where that wire goes.
Into the main harness......I think it's a fuel injection control of some sort, just haven't found it yet.
Today we're determined to make some 4th of July noise ourselves!
Don will be by in a bit and we'll finish buttoning up the Pup and see if it will pop off.
Yesterday we moved 37 cars in 100+ degree heat, doesn't seem like any big deal till you realize I drove over 500 miles yesterday and never left town - each trip is 35 miles one way and I moved 8 cars - do the math. It wasn't too bad till late in the day when I got that one car with no A/C.....surprised me too because it was an '08 Honda Civic, rare to have A/C fail in one of those. Drove two older Mercedes SLK - weird how we get pairs of cars like this.
On to the Pup then......
We talked it over and decided the extra connector went to the speedo sensor on the transmission......our logic went like this - since he has an aftermarket speedo it doesn't use the ECU connection to feed the speedo info, so Mini Tec made up their own harness for the Autometer speedo and the OEM one simply wasn't used. There is no other 3 prong square connector anywhere on the engine and it fits perfectly.......so that's what we did. We'll know later today.
Quote from: MiniDave on July 04, 2018, 08:47:56 AM
Your reasoning seems solid.  Now go tell the Pickup and see if it agrees.
Almost there, still have to bleed the brakes and clutch......
#61
First start!
Still have a fluid leak on the front brakes - not at the new line, although I did have to swap that too as the other one leaked at the subframe fitting - don't know WHAT was up with that but changing the line fixed that leak. Got the clutch bled out no problem, rear brakes bled out no problem. Just got to get this pesky leak in the fronts fixed, it's leaking at the T fitting that goes to the left and right front calipers. Unfortunately it's buried under the intake manifold......gonna be a bitch kitty to get at now....
I'm chuffed that it started on the first turn of the key, clutch works, gears shift smoothly, all the instruments work (except the speedo - he didn't look at it) and there was no noticeable vibration. That's not to say it's cured, but I'm convinced it's going to be leaps and bounds better than it was. Only took 10 years for him to let me fix it for him.....   ::) 77.gif
You and brake leaks!
Awaiting the report on the new gearing once it's road worthy.
Congratulations!  Always a great feeling when it starts right up after a rebuild!
Bahowe1
Dave,
What were the wire colors on that connector?
I made my own harness, so I may or may not be able to help.  I will certainly look tonight though.  If it's anything like mine, the gearbox that was for that original engine had a cable speedometer, so I switched it over to electric VSS.
Sounds good!!  Two weeks is nothing for all the work you guys did.  I think I had my gearbox open for a month - but I didn't order parts until I had it open and figured out what I needed.  Did you guys replace any synchros or gears while in there?
I think we have the wiring sorted, the wire colors were yellow, black and white but they are a made up harness, not OEM. We decided it went to the speed sensor on the trans, this one did not use a cable, but a transducer.
We did not replace any gearbox innards, before we took it apart it shifted fine, and all the bearings were smooth so we reused everything - even the bar of soap limited slip thingy.
He ran it thru the gears in the start up video and it shifted easily and cleanly.
Now if I can get the brake lines to stop leaking I'm calling it good!
Final report - the Pup is finished!
I tried 4 times to make a short brake line to connect between the bulkhead and the T fitting on the subframe and failed miserably - I decided it was the tool rather than the operator, so I rented a flare tool from another parts store - bingo - first time it worked perfectly.
Once we had all the leaks stopped it was just a matter of bleeding the brakes and putting the wheels back on.....the vid is of the first drive today - it ran perfectly.
Verdict? the car is transformed to use Don's words, It's like an actual Civic now, smooth and quiet with no vibrations, buzzes or rattles. He also likes the new final drive ratio tho we may have to go to poly bushes in the engine steadies as he thinks it moves around a little too much. I have a set and he can change them at his leisure at his house as they're easily reachable now.
Congratulations!   Job well done.   (And I like the surprise appearance of the Midget in the video).
#69
He's thrilled, he even took a short run up the highway, speedo is still accurate so apparently he has a GPS type speedo.....significant RPM improvement on the highway  - 55 mph is 2200, 70 is 3200 down from about 4K, 80 is 3600 so it will now be an easy highway car - coupled with the quiet and smooth instead of noisy and buzzy - the only negative is the cramped interior but he seems to fit it fine. With the bonnet off it seems to run quite a bit cooler - don't know if that's because it's getting better airflow or if the new water pump and thermostat are helping. He says the brakes feel a lot better too - we didn't do anything to them save new fluid and a thorough bleed. We'll know more after he puts the hood and grill back on. Considering just how many different things we worked on, clutch, cam belt, cooling system, brakes, transmission I'm pleased that we really had no problems save MiniTecs crappy brake lines, and now I've fixed those too. We also cured all his oil leaks along the way.....it's like a new car - or at least the way he hoped it would be all those years ago when he bought it!  ;D
Bahowe1
Sounds good Dave. How'd the torque steer turn out with the bar of soap when you nail it?
Bahowe1
I notice you guys also added a little radiator air scoop. What fan is he running?
Virtually no torque steer once I got the alignment set right.....a little in first but not much and none after that.
The little scoop might help get more air into the rad, it has a stock Honda fan behind the radiator. It runs about 190* unless he's sitting at a long light then it goes up to about 210 where the fan kicks on. It also has a small flap on the wheel well side pointing to the rear to help guide the air thru the rad.....
Nice work, a lot of issues sorted well done.
#74
Thanks, it was a lot of work, but like you said a lot of issues that got sorted once and for all. He's already done 30K in it and I expect he'll do a lot more now that it's so much more pleasant to drive. I just wish I fit in it!  ::) 77.gif
Between this car and his Midget, his '06 JCW sometimes sits for months......
