Adventures with a 68 Mini
Wow, that looks familiar.....you're doing a great job!   :13:
blaked
Some progress from last weekend. Fitted a couple closing panels and got most the perimeter of the floor done before depleting the shielding gas. More grinding, welding, and hamering before its done. Companion bin will be next. Does anyone have tips on welding the base of the bin to the floor?
mk2 cooper
blaked
Rear floor panel is complete! Fitted the front and rear slinger brackets and outer sill. Forgot to snag a few pics before closing it up - was really in the groove of just getting it done. This feels like the second big milestone for the car (with the first being the front end). Next up companion bin and boot floor!
mk2 cooper
You're killing it! Looks great.... :dance:
blaked
Another big weekend in the garage. Completed the plug welds on the outer sill, installed the companion bin, installed the ashtray, and test fit the boot floor. Really happy with how the boot floor is lining up with the bins, heel board and wheel arches. Shocking actually. With respect to the companion bin, I cheated a little and did fillet welds on what will be the vehicle's noticeable interior. I attempted to weld the flange from inside the bin; however, after one attempt I definitively concluded this was not the way for me. Perhaps possible for someone with actual skill in the craft. Certainly, I would have made a huge mess with poor quality welds in an unreachable location. Ultimately i'm happy with the outcome.
mk2 cooper
blaked
Spent the last month redoing the previous owners shotty repair work on the seat back including a rebuild of a portion of the flange that mates to the boot floor. Then I  cut out the stiffener bracket (betwen seat back and shock absorber turret) and cleaned all the mating flanges for to accept the boot floor. After much effort the boot floor is nearly in the final resting place. I wanted to test fit the large panel before welding in the new stiffener bracket and repairing the rear arches. Maybe another month before the boot floor actually goes in.
Question for the group - the new boot floor panel has several 1" or so diameter holes - 2 where the spare would go and 2 on seat pan. Would anyone recommend filling these? Ive never had a mini with a solid boot floor and intuitively i wouldn't think holes in the floor are a good idea.
Also threw in a pic of the outer sill after finish welds and grinding.
mk2 cooper
The boot floor holes are really for water drainage or fuel with the tank back there should you get a leak.  As easy as it is to weld them closed, I'd still just use the appropriate grommets. Customer car in the shop didn't have his fuel sensor unit sealing properly unbeknownst to me. I added 6 gallons of fuel and suddenly had it pouring from the holes which I hadn't added grommets to yet.
blaked
The last month was productive, but not much worth reporting on until now. Spent a lot of time hammering on the boot floor and cleaning the bottom flange of the seat back. I decided to cut off the floor to wheel arch brackets as the driver side was visibly corroded at the wheel arch. upon inspection a portion of the drivers side wheel arch needed to be replaced. Passenger side looks pretty good. Also fitted the seat back to wheel arch stiffening bracket.
mk2 cooper
blaked
Afternoon everyone. Back at it after another late summer break for burning man. Progress maintains! Tacked in the boot floor and confirmed the the rear subframe fits. Thankfully the rear trunion mounting holes lined up and the boot floor panel elevation seems right too.
mk2 cooper
I was going to try and pop by and say hello again. The one day I cruised by your camp on the way somewhere it was pretty desolate looking.
blaked
Appreciate you stopping by. Lost my phone Monday night. A classic symptom of an epic burn! Did you happen to find the tandem bicycle out there? Some friends and I built and brought it out. I designed the solar power and battery bank for it.
Light on updates, but steady progress. Finished welding the boot floor to the wheel arches, seat back, and installed the brackets for the rear subframe. Got the entire rear panel off and cleaned up the flanges. Most of the panels on this car are attached with what like a roller spot weld. Strong, but separation - completely impossible. So i had to do my best to completely remove the old flange by grinding while not totally destroying the one i intend to keep. The flange on the roof panel needs a small bit of repair, but otherwise pretty healthy.
Anyone know where i might be able to source the top half of an MK2 right rear quarter panel? The previous owner did some custom fabrication that id like to remove. The car has the original 1 piece side stamping (i think).
rb
mk2 cooper
I do remember seeing that bike out there!  Cool.
Are you looking for that section of B pillar above the rear quarter that's mangled up?
blaked
mk2 cooper
I think I have a section from a mk1.  Not sure if that matches.  I'll look to see when I get home next week if I have the sections.
If you didn't get the word Duane Flatmo passed away. My favorite art car out there.
Wow! Did he build that himself? That's freakin amazing.....
