Just ordered a Moke shell
Thanks for the update, wasn't that a new front sub? Broken welds, weak welds and doesn't even fit? Where did it come from so I will never order one from them?
Is it a single bolt or two bolt per side subframe?
Actually, it is more likely the shell need fiddling to get the subframe to fit.  I had to make some adjustments to mine and I reused my original front subframe.
The openings in the inner wing where the subframe towers go had too much edging and needed some grinding to fit.  (Like taking the flashing off model parts or from a fiberglass molding.)
Quote from: MiniDave on February 20, 2019, 10:24:41 AM
All UK, Australian and Chinese Mokes use two bolts per side sub frames Dave. The Portuguese and Cagiva Mokes use the single bolt ones.
Got a tag for the front.
In Georgia I can run a year of manufacture tag on the rear. Still have to have a state issued plate and sticker but it does not need to be mounted (just in the vehicle somewhere) as long as you have the YOM tag registered in the state system. So hunting for a 1966 license plate for the rear. Seen a bunch but nothing that I am willing to buy yet. There are even places that will restore the plate with baked on paint.
I remember when it was only Delaware that had a completely flat (non-embossed) license plate.  However my state went to the flat painted-on plates about 12 years ago, and so have a lot of other states too.  But the non-embossed plates still look fake to me - like bad movie props.
Deighton got YOM plates for three of his cars, Missouri allows you to register the car under the number on the plate, whatever it is. He had them all refurbished and the absolutely look brandy new.
Dave or Brad do either of you have the contact info for the plate restorers ?
I bought a brand new never issued 68 Florida plate and it is starting to rust and i want to refresh it before it gets too bad, i am guessing they did not make them from aluminum back then.
#57
I'll ask Deighton who did his...they absolutely look brandy new. I think he said baked on enamel.....
Here you go.....
Larry Niederschulte,
816-365-0447,
noomnoen@aol.com,
www.larryslicenseplates.com
#58
Thanks Dave i will get in touch with him.
Just a heads up Dave the website you posted is missing the e in license it should read larryslicenseplates.com.
Thanks again.
Cleaning the wiper motor I got. Even used and needing overhaul they are over $100, already done goes for $350.
These also fit contemporary Land Rovers too. I bet that added demand helps keep the prices high.
Got the last parts in for the wiper motor to finish. Turned out usable.
pbraun
Peter
65 Moke
60 Bugeye modified
66 Jaguar XJ13 ( I can wish )
#64
After spending more time than I liked trying to get the front subframe I had to fit I just got a new one from MiniSport. Not cheap but it is a whole lot closer to fitting. It looks like a few minor tweaks and it should work.  An extra good thing about it is that has a welded in bracket for a front lower engine steady. Need to fit the front sump guard, special one that were on mokes. Also open up the front mount holes to 1/2" for the tow bar.
Are both subs heritage or one a knockoff?
The front is heritage, don't remember about the rear.
I meant on the fronts. I wonder why one fits better than the other.
The other one came from a pile of parts I bought in years past so...
Is the new one the correct type of tower mounts (single big bolt per side, or two thinner bolts per side)?
It is a twin bolt. In the photo you can see the bolts with heads cut off for use as guide pins when fitting.
Welded in nuts for a sump guard. Anything else I might want to do to the new subframe before paint?
Hopefully go get my mini and the moke powerplant the first week in June.
Had some hats made for mokin'. Extra points for whomever figures out the logo takeoff.
The prancing moose?  :-)
What did Steve find wrong with the engine out of your red Mini?
Did you decide on a color for the Moke yet? Red maybe?
The timing chain cover was cracked, that was the major leak. Could not find the rattle and he said it all looked good and ran on the test stand ok. It is back in the car with a few minor items to finish.
Still leaning toward a very light shade of blue.
