How's the Weather Today?
Started by MiniDave, December 06, 2017, 06:24:03 PM
MiniDave and 4 Guests are viewing this topic.
skmini
-36C without the wind chill here this morning.  It's been highs of -31, lows of -40 for the past week.  The wind chill is a nonsense number at this temperature.  The good news is that the skies are clear and there's no snow in the forecast.
#526
Whew! -36??? That is some kind of cold - that's the kind that hurts your face even if you're only out to get the paper.....that's Arctic cold.
We had -4 (-20C) last night but it should warm way up to the mid teens for us later today.
Our neighbors came over real early this am and cleared the drive, sidewalk and front steps - they are some kind of good people!
A little later I'll broom off the cars and get that part of the drive cleared so she can use her car, I can't think of anyplace I need to go right now! Garage got colder that I've ever seen it last night - right at 32* - I was concerned because I have a lot of stuff in there that can freeze - it normally stays around 40 in winter.
ve9aa
BRRR. Matthew.
It's "warmed up" here.  Got to -27°C with the wind chill (actual was around -17°C) with moderate winds and snow.
Now it's currently -14°C, windy and snowing pretty good.
I think we'll get "every inch"(haha) of that 30cms they're calling for. (Metric joke)
Tractor will get a work out first thing tmw morning once it's all done.
Mike in NB
Do you have a blower or a blade on the tractor?
skmini
Quote from: ve9aa on January 26, 2026, 10:01:22 AMBRRR. Matthew.
I think Matthew goes by "Spitz" on here.  I'm yet another guy with a Mini in Saskatchewan.
ve9aa
Quote from: MiniDave on January 26, 2026, 05:43:25 PMDo you have a blower or a blade on the tractor?
Front blower. Small Kubota tractor...BX2380
Mike in NB
ve9aa
Quote from: skmini on January 26, 2026, 08:56:42 PM
SORRY !
Mike in NB
My time in the tropics is coming to an end. Shorts and short sleeves no more.  If I didn't have a mountain of things to do at home I'd just stay here another week.
It's actually going to be pretty nice here later in the week, mid -50's for us so probably even warmer for you.....in fact if you can delay it till Thursday, you'll come home to 60's and 70's!
Dan Moffet
It feels like a real Canadian winter here for a change. I hadn't driven the Jeep (2010 Liberty) for over a week and the weather turned properly cold. It is currently -18C and was -21C when I got up at 8:00 AM. And then there's wind chill. So realistically the Jeep engine was probably about -25C.
Yesterday, I was going for beer and the Jeep would only make a few grumpy "Don't even think about waking me up" noises. The solenoid worked and the starter could only muster a half revolution on the V6, if at that.
This morning I ventured out to see what could be done. (The Jeep lives outdoors.) Still no start, so into the garage to search for the battery charger I probably have not used in 25 years or more. Found it! The next challenge was to uncoil an extension cord to plug in the battery charger.
I did have a cursory look for a block heater cord which typically would be visible inside a front corner of engine bay. No luck there. But once the battery charger was humming, I had a deeper dive. Since the Jeep has been pretty well behaved, I was not really familiar with the V6, so had a closer look at it.
There... lo-and-behold... on top of the engine under a collection of tubes and wires was a flat 3-wire extension cord style bundle of wire with a factory installed zip tie and a covered 3-prong plug on the end. That'd be where it was tucked during assembly of the engine and had never been touched since.
So, now the charger is plugged into one garage outlet and the block heater into another. I'll leave it for a few hours
I'm working with the shop door open today.
#536
Yeah, it' supposed to be 70 (+21C) here tomorrow - I have plans to take the Audi over to JP's and wrap the Honda Rodent Proof Tape all over the wiring harness. I still have some things that aren't working quite right, so I'm hopeful I can find where the farking bastiches got into it and get it fixed. If I can't find it I kinda hate to wrap up the harness in case I have to take it back to Audi for another round......if I do I'm filing an insurance claim.
I opened the hood on the white car and found masses of nut remains and such all over the engine compartment. Maybe I should use the HRPT on it since it's all working perfectly.
My cars both started just fine when it was -5F (-21C) here last week or so, I guess running that 5W30 synthetic oil helps it turn over.
Dan Moffet
#537
Quote from: 94touring on February 08, 2026, 12:30:53 PMI'm working with the shop door open today.
Yeah, I was working with the garage door open too. :cheesy:
After 2 hours, the Jeep still groaned, That's when I discovered the GFI the bloc
 heater was plugged into had tripped. Reset it and waited 2 more hours. Success!
For those who don't know what a block heater is, it is a smallish immersion heater that fits into a freeze-plug opening. It warms the coolant in the block.
Pretty much a requisite in the great white north isn't it?
Dan Moffet
Quote from: MiniDave on February 08, 2026, 06:26:40 PMPretty much a requisite in the great white north isn't it?
Yes, it used to be, though I'm not sure if it is standard any more. This is the first time I have used a block heater in many, many years. With computer controlled engines, the starting process is usually enough to overcome the cold. But my Jeep sat too long without being run and got too stiff. I also think it was a bit peeved in being demoted to being an outdoor vehicle - it had enjoyed being the garage car since we bought it but was usurped by the Honda HRV we acquired last summer. The garage is unheated, but attached to the house, between being sheltered from the wind and cold, there is the heat-sink effect of the concrete and ground below the slab that it does not get as cold as outdoors.
Speaking of block heaters... this was the first winter I didn't have to heat up my giant air compressor that sits outside in the car port.  Whenever I did some refresh items last year and was able to swap to oil the owner manual I found online recommended, it cranks right up without tripping breakers.
It's supposed to rain all day today which gets a big YAY! from me as it will wash all the tons of salt off the streets around here. They must have had left over salt this winter cause I found mounds of it in the intersections and along the curbs....the good news is a few days ago the street sweeper came thru and  cleaned a lot of it up, the rain should get the worst of it rinsed off the streets and people will feel a lot better about bringing out their classic cars.
We should have 60's and 70's all next week - hardly February weather for Kansas. We're used to having snow and ice storms this time of year.
It was a sunny 82° here today in south central Texas. That's alot warmer than some past Februarys. A month ago it was 14° here, which is pretty cold for these parts. We've gone from having the heat on to the air conditioning on in  just several days.
I left at 2 pm to drive up to Prather Racing, we took Scott's racecar up so he can drop the motor and gearbox in at a later time.....it was 64* when we left, it was 34* at 6 pm when we left Wakarusa to come home! Dropped 30* in just a few hours.....
We're headed for highs in the low 30's the next few days, then it will be 70 next Monday - welcome to Kansas!   :grin:
Well as predicted by the weather guessers, it did warm up nicely here in Kansas - this whole week has been brilliantly sunny and pleasant, each day getting a little warmer till Sat when we'll have 70+ temps, followed on Sunday by a high of 30!
I'm headed to Phoenix for a week to help my kid with a project - he has his own shop that is mostly a hobby shop but he does take on some customer jobs from time to time. This job is a TR3 that won't run - right in my wheelhouse! Leaving the 10th and back on the 15th - flying out this time. I haven't flown anywhere in probably 20 years now - we always drove to see the kids so we could haul the Pups with us, but they're staying home and so is the other half.
Temps should be in the 90's there - but it's a dry heat..... :rolleyes:
84* and muggy today, tomorrow's high will be 48!
Sunday night it's supposed to get down to 18*....and I already took the heater out of the bird bath.....oh well, it will warm up later in the day.
I'm leaving for Phoenix today, I think the last time I flew was 2004 when I went to my mom's funeral in California. I'm not afraid to fly, it's just such a miserable experience that I usually just drive, even across the country like this. I can do Phoenix in 2 days each way. Going to see my daughter in North Carolina is 14 hours or one 8 hour and one 6 hour day - no biggy. Today I leave KC at 2:50 and arrive Phoenix at 3:30 -  No motels, no lousy junk food all day and looking for a decent place to eat that night....it's like time travel!
Going to be mid 90's in Phoenix - don't know if I'm ready for that!
after being bombed with snow and below normal temperatures in Southern Maine, we had two "spring preview" days Monday and Tuesday. Activated the Mini's insurance Sunday evening, and commuted (14 miles each way) to work. Ran like a champ!
@ndyray
Dan Moffet
We've had balmy weather too the last few days. Much of the snow has disappeared and the roads are bare and dry, if pretty rough from frost heave, potholes etc. They were even free of salt dust! I actually was thinking about reactivating Mini insurance too.
BUT! Today we have freezing rain, for the next couple of days. Orange freezing rain warning - better than the yellow snow warning a couple of weeks ago. So the salt trucks will be out again in force, if the City has any salt left. (sigh).
22 right now and 92 this weekend  :017:
