joakwin
Quote from: MiniDave on September 02, 2019, 02:40:07 PM
OK, waiting to see what you're doing with that.....  ;D
Edit: posted at the same time!
lol
still waiting on paint to dry, it feels dry but soft at the same time
but we have rain coming in, so I put the other mirror mount back on for the time being, to seal the holes in the door
the new mount should be good tomorrow
I hope the mount gives me the inward movement, im just kind of guessing at this point
if its not good, then I will go and get some 5/8's alloy plate and build it over again.....gives me a reason to use the mill more, lol
I get a 10% discount on the metal and I get it from the left over cut section and its a ton cheaper then normal price
joakwin
#476
I have done anything to the mini in a few weeks, its been super hot here and im waiting for the summer heat to be gone,
so I started another project to take my mind off the mini for a bit
joakwin
How are the projects going still working in the truck?
joakwin
Hello everyone
I'm still slowly working on the truck
Been building the floors inside the truck cab
I'm going to be moving up to Utah soon
Glad to hear from you again! Hope everything is OK for you and yours..... 77.gif
joakwin
joakwin
ended up using a gen 1 s10 blazer fuel tank, tbi sender unit with upgraded fuel pump, and then converted the send/return to -6an fittings, and used -6an fuel hose, and a stock gm filter with -6 an adapter fittings
joakwin
92840633_10158161976986684_6138068256704954368_n by joa kwin, on Flickr
this was last April, i didnt take a pic with the front all the way lowered
joakwin
Quote from: MiniDave on October 05, 2020, 02:02:05 PM
yeah, everyone is good
kids are still doing home schooling, so im pretty much the teacher now or baby sitter, lol
so working on projects has slowed down alot
they are about to get 2 weeks off from school, so thats going to be nice
im cleaning my garage right now, i recycled 800lbs of metal the other day, and i got a 2nd load im about to take but its not as big
im taking a job north of salt lake city.....so i gotta let alot of stuff go, so that i can keep alot of my audio gear
so im just getting ready for the move, moving is always alot of work, but its a good time to trash alot of stuff thats not needed
joakwin
23937350863_fb7e09dfd4_b by joa kwin, on Flickr
im thinking about lifting this mini, or maybe the od green mini, not sure yet
but a small lift would be nice for winter driving in the snow in Utah,
i do have my awd honda pilot, so a mini wont be a daily in the winter, but more for fun then anything
joakwin
the d16z6 in the green mini starts to smoke white when the engine gets hot,
i think i got a cracked head,
besides that, the motor runs good
i mean, ive done the timing belt, water pump, head gasket with new head bolts, crank pulley,
oil pan gasket and front and rear main seals
im not sure how much longer im going to stay with this d16z6 motor in this car
unless i find another head for super cheap
joakwin
74232828_721810444991578_7245173227746492416_n by joa kwin, on Flickr
i built a pair of these horns, they are 22x14, and sport 4, 1inch horn drivers on the back of them, they get crazy loud with a small amount of power
they are made with 16ga sheet metal and then i used bed liner to try and dampen them down,
they are on the bright side but thats how i like my tweeters to be
joakwin
115936139_900121057140376_5997219942775336997_n by joa kwin, on Flickr
helped my uncle with this, 2.5 week rebuild of his 94 k2500 chevy truck
2004 lm7 5.3 with 4l60e, and obs t case
5.3 has a summit 4x4 cam in it
this truck was straight nasty, the frame had dirt inside of it, but my uncle got a 4000 psi pressure washer from a friend, and took half day or so to clean it out, half day to dry, and then 2 days for por 15, primer and paint the frame and underside of the cab
did the rear brakes shoes and gear oil, front axles, upper arms, lower ball joints,
radiator core support bushings were replaced, and everything was taken off and cleaned and painted pretty much
115930518_318931529290678_1526240242116789886_n by joa kwin, on Flickr
drive shafts got new u joints and painted
115943682_291426818848631_4254663947297956732_n by joa kwin, on Flickr
repainted the firewall
117146662_314020823292059_934344732801248906_n by joa kwin, on Flickr
radiator set up with dual e fans
116856379_220402565887147_2106071266820294510_n by joa kwin, on Flickr
joakwin
joakwin
video-1597268730 (1) by joa kwin, on Flickr
drove from tucson to northern washington to knock this swap out in 2.5 weeks
joakwin
Wow, you've been busy!
Love the barber pole paint on the driveshafts!   ;D
joakwin
just checking in
im looking for a 998 engine and box
but im kind of thinking geo metro 3 banger would be kind of fun
I have a 1098 and rod change.  Complete with subframe and suspension bits.  $500.
joakwin
got this set up in the garage now
joakwin
i moved from Tucson to Utah and have been working on the house and garage for almost a year now
this is the over the garage door storage i started to build a few months ago, its 22x11 with attic door steps going into it
and im putting in a shop vac
joakwin
i picked up this frame last winter, its a cj7 frame, it will need some cutting done to it but i would like to sit a mini shell on top of it
its sitting on 35's
joakwin
1991 geo metro drivetrain i rebuilt
making it fit inside of a mini subframe with a jig that i made
7.5 brakes i got, because i want 10 inch wheels
this b38 lhd mini is getting the geo swap, after i rebuild the shell
joakwin
