help me choose a new radiator
Started by ADRay, October 21, 2017, 05:27:28 AM
ADRay
I need to replace the radiator for my 998cc motor, but the situation is a little unusual. The head is a ported and polished unit that was installed 3 years ago. it is unusual in that it doesn't have a port for the temp sensor. There seem to be a lot of choices as far as material or number of cores, and I want to make sure I choose the right one.
I want to do three things:
1: Replace radiator and all hoses
2: somehow reinstall the temp sending unit (drain plug port on radiator?)
3: possibly remove the heater
Thanks
1982 Mini 1000 HL
@andyray998
Tap and die the head for the sensor in the stock location.  Buy chinese aluminum radiator off eBay.  Why do you want to remove your heater?
Is there a plug in the hole for the standard location in the head is is it not drilled?
The replacement 998 head I recently got has a plug that can be removed in order to install the temperature sensor.
#3
Would this work?
Otherwise, it's fairly easy to drill and tap the head for the sensor, it's usually a pipe thread, and you can buy pipe taps at any hardware store....just get the right one. If you use this housing you need the temp sensor that fits it - a 10 mm thread rather than pipe thread.
http://www.minispares.com/product/Classic/Engine/Cylinder_heads/Head_components/PEQ10010.aspx?100402&ReturnUrl=/search/classic/thermostat housing.aspx|Back to search
#4
I like these radiators......not necessarily this exact one, although this one is good cause it has the petcock drain with it....and look at the price!
https://www.ebay.com/itm/Aluminum-Radiator-For-67-91-AUSTIN-ROVER-MINI-COOPER-MORRIS-ALL-MODELS-MANUAL-/332251904678?hash=item4d5bc1baa6:g:A94AAOSwd4tUD-nk&vxp=mtr
This one is made slightly differently but still has a drain plug.
https://www.ebay.com/itm/50-mm-2-rows-Aluminum-Radiator-for-AUSTIN-ROVER-MINI-1275-GT-1959-1997-Manual-/121631809037?hash=item1c51d21e0d:g:8EkAAOSwPgxVOh1T&vxp=mtr
That's the rad I've put in several cars and even on long highway runs on extremely hot days it does not run hot -stays dead in the middle of the gauge. For the money I think these are a great deal.
Yeah those ebay rads are hard to beat.  I've probably installed half a dozen or more. Just make sure of the thickness.  Some are 45mm and other's 50 or 52. I think I have a 52, lots of capacity!
ADRay
#7
thanks everyone. seems I need to look out for thick a walled unit more than anything.
I had thought of drilling and tapping the thermostat housing, much like that unit. Would that fit my head? another option is maybe on the heater outlet port if I remove the heater, but I don't think I'll have the back spacing though.
This is the corner of the head where the port should be. While drilling & tapping would probably be best, I'm not keen on taking it apart to do so at this point
1982 Mini 1000 HL
@andyray998
Interesting that your head does not even have the flat spot in the casting for drilling and tapping a temperature sensor hole in the normal place (below the thermostat).
I would try going with something like the thermostat housing Dave posted.
#9
DSN Retrosport also have thermostat housing with temp sensor ports.
I may have one of the ones that Dave posted. (Edit: can't seem to find it)
How early is the car? The early MK I's with the radiator shroud on the inside fender can require some modification if using a non-standard radiator.
Terry
Lone Star Mini
Dave and/or all....   the ebay radiators are certainly well priced.  Most of them state they go up to a '91.  what is the difference between a '91 (earlier) and '92?  I'm not sure, but given input from another post, my daily driver may be a '92. Therefore what should I look for in a radiator (ebay wise)?  Thanks anyone.
Lone Star Mini
1992(?) Mini Cooper
1964 Austin Cooper
1980 Mini 95 (Pickup)
I believe the difference is the later models have a sensor built in for the aux fan and the overflow pipe may be a different angle for overflow tanks.
ADRay
ended up going with the 50mm. awaiting installation, stay tuned.
1982 Mini 1000 HL
@andyray998
No question, if everything else is working properly (water pump, block isn't full of sediment etc) that will do the trick!
I had to make a small notch in the fender for clearance on mine.
Lone Star Mini
Quote from: MiniDave on April 25, 2018, 01:57:12 PM
@Dave,  any chance you can take a pic or provide an idea of location of the notch you made?  This will simply serve as an awareness when I get mine and begin to check fit it
@ADRay,  keenly interested in seeing how yours goes in
Lone Star Mini
1992(?) Mini Cooper
1964 Austin Cooper
Here you go.....I didn't finish it very well.   ::)  I did that after the radiator was already in place and I didn't want to take it out again.
Lone Star Mini
thanks Dave.. I'll have to go out and look to see if I can figure out where this 'notch' might be...
Lone Star Mini
1992(?) Mini Cooper
1964 Austin Cooper
I only needed to hammer that section in a hair.
joakwin
i did a ebay, alloy rover mini radiator on my stockish 998 car, i think it was $55 or $60 for the part
no problems with over heating daily driving it in the AZ Tucson heat in the summer, i didn't even have the heater hooked up and i had the stock yellow fan
