Racing Green 89 Mini
I had ordered a new Lucas Sport coil which came in yesterday - surprised me since I only ordered it Wed afternoon and it was here Friday! Anyway, bolted that in last night and boom, car started instantly and I could feel the difference even just running in the garage.
Drove it to brekky this morning and again - started on the first turn of the key, idled better and ran perfectly, engine def feels smoother too.
I have a new set of wires and plugs on the way, and I got a valve cover gasket too as I haven't checked the valve adjustment in a while, so.....time for some maintenance.
It also feels like something's loose in the front end, it tramlines and darts around under braking - never did that before.
I need to pull the fuel tank and see if I have a leak like Bruce found as I also have a LOT of fuel smell when the car has sat for a bit.
Yeah see it's a noticeable difference!  Those lucas sport coils are 40k too after researching them
#727
Ok, cool!
I'm def happy with the improvement..... I wonder how long it's been on there, and how long it's been going bad? I think quite a while actually, to both questions.
I'm thinking I may wind up pulling the motor this winter and see if I can fix the oil leaks once and for all, and while it's out give it a better coat of paint.
Was it just a regular coil and not the higher voltage?
The inno dizzy uses the low ohm coils. It idles different going from 1.5 to 3.
Didn't look at the specs, just that it's the Lucas Sport coil, 3 ohm.
Since I don't have a radio nor intend to get one, on advice from Kent I ordered a new set of plug wires with copper cores, and some new firing pins just because.
But it's probably overkill as it's running perfectly now. I need to drop the idle back too, as it seems to have gained about 200 rpm.
I was wondering what the old coil was.
I'll see 100-200 rpm difference between low ohm and high ohm too.  I run non resistance plugs also.
I still have the old one, I can measure the resistance of the low voltage side and see if there's something going on there....
Quote from: MiniDave on November 24, 2025, 09:14:43 AMI still have the old one, I can measure the resistance of the low voltage side and see if there's something going on there....
I was curious because if the idle is up a couple hundred, even when the old coil was working properly, it would be interesting to know what the old coil voltage was to compare improvement to a 40k volt. Do you plan to regap the new plugs wider too?  It's another small benefit.
Old coil Ohm'd out at 3 ohms, kind of a disappointment - I had hoped to see something off there. The new one def runs better, starts way easier than it has for a very long time.
Dunno about the plugs, I suppose I can try them wider and see what happens.
Doing some maintenance on the Racing Green, it may have a leaking radiator - I need to find a shop that can pressure test it to see.
I also was thinking it was time for new cones, can't decide if these are bad enough to bother with or not...I don't have new ones to compare them to.....
Whadya think? Squished or OK for a while more?
