Vikram's 1960
It pretty much has to be what jeff posted.  The threaded object must be tight enough that coolant doesn't seap out.
yes what i posted is what you need and fairly common 3/8 npt male is basically 5/8 18 with a taper, the other end is 5/8 18 and will accept the sender.
Vikram
Quote from: jeff10049 on August 21, 2016, 12:08:24 PM
Ohhh. Didn't know that.
Thank you
you could also get a 3/8 close nipple and a 3/8 female union at about any hardware store and see how well the union accepts the sender. That way you don't have to order something
Also I'll get the horn wire pics up today
ok no real need for pics I ohm'ed out my horn wires the brown with green trace at the horn goes to the bottom fuse of the fuse block. The brown with black trace at the horn goes to the horn button.  Also brown black at the stalk.
Vikram
Thanks Jeff.
So I went to Napa to see if I could get a fitting. They didn't have anything that would work, the 3/8npt would start, but wouldn't thread.
However Dan had a bunch of fittings in a bucket, and I found one with a female 5/8 end that I took to the store. While I was there, I though of just cutting off the end, and having a small spacer with a 5/8 thread.
So that's what I did. Seems to work. All its doing is just moving the sender out far enough so that it can be torqued down without hitting that wall. It still grounds on the block.
Will this work?
Vikram
Well that's all from me, I leave tomorrow late morning.
Got the new starter in, engine now cranks nicely. So I think that's the wiring done.
New rear hubs and bearings on too, along with the spaced drum.
Picked up the new wheels from powder coating and got the tyres mounted.
Dan will bring it from 90% to 95% so that it's running and aligned. I'll trailer it back, and finish off the last few bits. Just in time for winter!
Anyway, it's been an awesome experience. I've learnt more in three months that two years at college.
Thank you to all you guys on the forum, your help has been invaluable. Everyone who I've met in person, Justin, Dave, Stan you've been really welcoming to the community.
This is by by far the best forum out there.
Last but not least, thanks Dan. Thanks for the opportunity,all your help and expertise, it's been amazing.
I guess minimania did one good thing in bring me here.
I haven't been particularly active in your build, but have checked your progress regularly.  To say that I'm impressed wouldn't do you justice; I'm really impressed.
Even though Dan will do some of the finishing work on it is no reason for you to leave.  You'll own the car for a while, right?  You've made some friends, right?  Well, since you've already established a login and the server already has some uploaded pics, you might as well stay.  The internet can help bridge geographic gaps.
Keep participating within 'our' community - socially or advisory, I'm pretty sure you'll be welcomed.
Vikram
Oh I have no intention of leaving, and I see my self owning the car for a long time. I just won't be local anymore.
That being said, if anyone does end up in my neck of the woods let me know! We can grab a drink, I'll be 21 by then lol
I'm glad you had the opportunity to come out and literally build your car.  It's been a pleasure!  You'll have a cool story to take with you for the rest of your life.
It has indeed been impressive to watch your progress!
The "community" on this forum is widely dispersed as well - all across the USA and into Europe as well.  You are in good company and always a member in the community.  Keep us posted on the progress even when you get your Mini back home.
He's only going back to Michigan!   ;D
stan360
#162
Best of luck at school and finishing the build Vikram.  You accomplished quite a bit in a short amount of time.  There is always next summer, maybe you can build  another mini project then  .  ;D
Vikram
Thank you for the kind words. I'm hoping to get it on the road by the end of the year, but probably actually drive it next year to avoid the snow.
Yea that should work maybe a copper washer between it and the block at some point. But if its sealed it's sealed leave it be.
Or run a 3/8 npt tap in the head at some point if needed for more thread engagment and buy a thing like I posted. But again if it's working I'd leave it be.
It's been fun watching the progress you got more done while at Dans than I did in 5 years.
Jeff
Dmulder
Vikram, where will you be located in Michigan?  I'm on the Lake Michigan coast and there are at least 2 and I believe 3 classic minis in my local area.  I don't drink but it might be fun to meet up some time.
September 9th I will be running the Press On Regardless TSD rally in upper Michigan with my classic mini.
Tim
I'm across the border into Ontario.  If you ever want a slightly longer drive (to north of Toronto  71.gif),  email and say you're comming!
Tim
Vikram
I'm not in Michigan haha, Dave's got it mixed up. I'm in Troy, near Albany in NY
Got the gauges today Vikram - thanks! Hope I can do something for you someday too.....
Sorry for the mixup, for some reason I thought you were going to school in Detroit or something........
Vikram
Great! I think there's a Troy in Michigan too haha
Got Vikram's gauges installed and ........they all work! It's like they were meant to go in there or something..... :-)
Finally got this thing running.  After much fiddling with carbs, manifolds, linkages, cables, and a few other odds and ends.  Not too much more to go.
I should add he's equipped with a specially designed throttle cable guide that feeds the cable through the firewall.  For whatever reason the left side of his car didnt have the little guide piece that the cable end fits into.  It was a pita.
Quote from: 94touring on October 16, 2016, 03:46:35 AM
Maybe he'll come back at Xmas to pick it up?
I think Hugh will be picking it up.  I'm excited to test drive it lol.
