Restoration-Mini
Technical Forums => Maintenance and Modifications => Topic started by: tmsmini on March 30, 2020, 08:10:09 AM
Title: Rear Alignment and Adjustable Suspension
Post by: tmsmini on March 30, 2020, 08:10:09 AM
After I had our sportpack saloon aligned, there was -1.3 camber on the rear right. The adjustable bracket was at full. I believe it is a MiniSport bracket or a close knockoff. I am guessing the trailing arm is tweaked.
Does anyone know if the KAD brackets have a greater range of adjustment? I see that MiniSpares have changed the design of their camber/toe bracket.
MiniSpares
NEGATIVE CAMBER BRACKETS REAR FIXED
http://minispares.com/product/classic/MS69.aspx
(http://minispares.com/product/classic/MS69.aspx)
CAMBER BRACKETS REAR ADJUSTABLE
http://minispares.com/product/classic/MS70.aspx (http://minispares.com/product/classic/MS70.aspx)
CAMBER AND TOE REAR TRACK ADJUSTMENT BRACKETS
http://minispares.com/product/Classic/Suspension/Subframes/Fixings_mountings/MS73EVO.aspx
(http://minispares.com/product/Classic/Suspension/Subframes/Fixings_mountings/MS73EVO.aspx)
MiniSport
Negative Camber & Tracking Rear Brackets pair
https://www.minisport.com/mslms0510-fully-adjustable-mini-negative-camber-tracking-rear-brackets-pair.html (https://www.minisport.com/mslms0510-fully-adjustable-mini-negative-camber-tracking-rear-brackets-pair.html)
Seven
Adjustable Rear Camber & Toe Brackets (SSS0041)
https://www.7ent.com/products/adjustable-rear-camber-toe-brackets-sss0041.html (https://www.7ent.com/products/adjustable-rear-camber-toe-brackets-sss0041.html)
Adjustable Rear Camber & Toe Bracket Set (SSS0044)
https://www.7ent.com/products/adjustable-rear-camber-toe-bracket-set-sss0044.html (https://www.7ent.com/products/adjustable-rear-camber-toe-bracket-set-sss0044.html)
KAD
REAR CAMBER/TOE BRACKETS
https://kentautodevelopments.com/collections/suspension/products/kad-rear-camber-toe-brackets
(https://kentautodevelopments.com/collections/suspension/products/kad-rear-camber-toe-brackets)
With the pound/dollar rate, the KAD seems appealing at this point, over the top still though. I did send them an email asking about the range of adjustment.
Title: Re: Rear Alignment and Adjustable Suspension
Post by: 94touring on March 30, 2020, 08:34:26 AM
Seems like one side on my rear end when I rebuilt it and using the spares style wouldn't go negative enough for me by a smidge. I took a dremel and made the travel to the desired amount, then locked it all down.  Negative 0.5 to 0.75 is about all you'll want on the rear.
Post by: 94touring on March 30, 2020, 08:41:47 AM
Depending how much free time and desire to tinker with it yourself...I bought one of these to do mine.  I also do my own toe.
Post by: tmsmini on March 30, 2020, 09:03:43 AM
I am trying to figure out if a Dremel or a new set is the better option.
The MiniSport knockoffs I have appear to have less metal to grind on.
KAD
(https://cdn.shopify.com/s/files/1/1300/5739/products/Rear_Suspension_-_Bolt_on_Camber-Toe_Brackets_1024x1024.jpg?v=1478691751)
MiniSport and others
(https://usa.minisport.com/media/catalog/product/cache/d22765a88f64711393c96456ac42e5a9/m/s/mslms0510.jpg)
Post by: MiniDave on March 30, 2020, 10:15:39 AM
I always buy the Mini sports, which are a KAD knockoff but 1/3 the price, and I have had to make the holes longer to get the toe right on my cars in the past, but I prefer that design to the MiniSpares, I've used both.
Post by: gr8kornholio on March 30, 2020, 10:41:37 AM
Can second the mini sport version. Very easy.  The others I tried were from mini spares.  Way over complicated
Post by: tmsmini on March 30, 2020, 10:59:09 AM
I have the MiniSport version.
According to the KAD site:
"Each serration on the plate is worth 1/2 a degree of camber and toe is adjustable."
I wonder if this is true for the MiniSport version as well.
Without removing them I cannot tell how much I would have to grind.
The Joe's gauge would be handy, it seems. No problem getting it to attach to both front and rear hubs?
Post by: 94touring on March 30, 2020, 11:06:32 AM
So the way I do it is I took the plates I use for measuring toe, and I have one with a steel plate bolted to the face. The gauge mounts by magnets. Then I position the plate on the wheel face centered up to the hub and take my measurements.
