Restoration-Mini
Technical Forums => Restorations => Topic started by: BruceK on August 25, 2018, 12:09:58 PM
Title: Choke cable
Post by: BruceK on August 25, 2018, 12:09:58 PM
 I'm replacing the choke cable on my car and when I pulled the old one out I was surprised to see there is a spade electrical connection on the cable. I haven't seen that before. Is it to ground the cable? Or is it for some type of warning light  that you still got the choke pulled on?    I don't see any wire that would hook to that so perhaps this is from an Austin Metro or something?   Also has a clip to secure it to the switch panel – I'm used to seeing the screw on type.
Title: Re: Choke cable
Post by: gr8kornholio on August 25, 2018, 12:36:35 PM
Yea, both of mine are the screw on type.  Along with the one that came with my 22R's Weber.  I think you're on the right track though that it may be some warning light wire.
Could be used as a security feature also.  Hook some voltage through a switch to it.  If you don't turn off the switch and someone tries to pull your choke they get a fun surprise.   ;D
Post by: BruceK on August 25, 2018, 10:04:04 PM
Quote from: Whee on August 25, 2018, 08:30:55 PM
I remember the metro having a orange choke warning light.
That must be it.
My generic replacement choke cable is 60" long - about double what is needed for a Mini.  Easy to shorten, but I wonder what car would a choke cable that long?
Post by: MiniDave on August 26, 2018, 06:49:02 AM
Where did you get it? I need a really long one for my engine stand...
Post by: gr8kornholio on August 26, 2018, 08:36:52 AM
The twist lock one I got from 7 was long but I was using it on my Toyota so it was fine. Don't remember what he said it was for.
Post by: BruceK on August 26, 2018, 08:52:55 AM
Quote from: MiniDave on August 26, 2018, 06:49:02 AM
I purchased two choke cables during a trip to the UK years ago.  Want the 2nd one?  It's a locking style, brand new, and I just measured it - over 6ft long.
Post by: MiniDave on August 26, 2018, 09:54:41 AM
That would be great, thanks! Anything that you need I have that I could trade you for it?
Post by: BruceK on August 26, 2018, 11:31:31 AM
Nothing comes to mind, so I'll take a rain check.    ;D
Post by: MiniDave on August 26, 2018, 12:04:20 PM
I don't need it right away, maybe bring it with you to the Oct Dyno Day?
Post by: BruceK on August 26, 2018, 12:47:17 PM
Oh. Okay. No problem.  Remember to remind me please.
