A moke I was working on had new 008's. The tires have a red dot and a yellow dot on the side walls.
I think one color denotes valve stem location. The other is denotes heaviest point of the tire.
Help which is which!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Regards
Red dot lines up with the valve stem. You can also look inside the tire for the overlap, that will be the "tallest" point on the tire, should be near the valve stem......
I've read online , red highest point, yellow line up with valve stem.
Any body chime in please.
Regards
Could be right, but I always read line up the high point with the valve stem.....
