Restoration-Mini
Technical Forums => Maintenance and Modifications => Topic started by: Spitz on November 02, 2015, 08:22:13 PM
Title: Fresh air hose.
Post by: Spitz on November 02, 2015, 08:22:13 PM
Is this available?
The hose goes from under the bonnet through the dash and down to the early fresh air heater.  Opening on the heater is 3.25".
I have all of the coil....maybe it can be covered(?)
Also....how do I detach the window defrost tube from the back of the heater?  Don't want to bust anything
Title: Re: Fresh air hose.
Post by: MPlayle on November 02, 2015, 08:31:46 PM
I have heard that McMaster has tubing similar to the large diameter fresh air hose.
As for the smaller demister hose, from the picture you attached I would try "unscrewing" it some and see if it loosens.  I don't have much familiarity with those earlier style heaters.  The early Minis I've had had slightly later heaters where the demister hoses slid over the outlets on the sides.
Post by: 94touring on November 03, 2015, 03:29:27 AM
I'd try unscrewing the small hose.  The big hose I've often wondered if the rv hose I see in wal mart in the automotive aisle is the same diameter.
Post by: MiniDave on November 03, 2015, 10:00:18 AM
Are those rocks inside the large opening?????
(http://www.restorationmini.com/forum/index.php?action=dlattach;topic=858.0;attach=3458;image)
Post by: Spitz on November 03, 2015, 02:59:10 PM
No...they are oblong food pellets of some kind I think...maybe burner pellets(?)   They heater was absolutely full of it....obviously a mouse was making a home or stash
Post by: tmsmini on November 05, 2015, 01:02:37 PM
McMaster definitely has the duct.
7 Enterprises may now be selling it as well.
This what I used:
5499K447 High-Temperature Blo-R-Vac Duct Hose for Dust, 3-1/4" ID, 3-3/8" OD, Black, 12' Length
http://www.mcmaster.com/#catalog/121/254/=zojsvi (http://www.mcmaster.com/#catalog/121/254/=zojsvi)
Terry
Post by: Spitz on November 06, 2015, 08:00:09 AM
Thanks very much for that link....thqat is some pricey stuff!  ( was that a typo you made...should it be 5499K247?)
Is the cheaper stuff above it ( 3.5"OD 53145K64 ) going to be too large to fit through the holes?  It's nearly 1/2 the price
BTW...I got the small hose out...yes, by turning it out.
Is the defrost tubing available?
Post by: tmsmini on November 09, 2015, 01:01:12 PM
Yes, the price has gone way up since I last ordered.
They have other materials, but I went for the heat resistant double coated style
