Restoration-Mini
Technical Forums => Restorations => Shop Tools And Equipment => Topic started by: 94touring on July 16, 2024, 10:19:49 AM
Title: My wonky ball joint tool
Post by: 94touring on July 16, 2024, 10:19:49 AM
I've never bought the appropriate wrench that fit our ball joints. I do have a large socket that I believe is used on the hubs for my bus.  Instead of using vice grips or a large pliers and struggling, I opted to use this socket. The problem is the stud of the ball joint sticks up and you can't get a ratchet on it.  *Wheel out the welder.  Welded a grade 8 stud onto the socket to stick a breaker bar onto it and voilĂ .
Title: Re: My wonky ball joint tool
Post by: Willie_B on July 16, 2024, 06:01:48 PM
That will work but how do you torque it?
Post by: 94touring on July 16, 2024, 06:28:24 PM
Quote from: Willie_B on July 16, 2024, 06:01:48 PMThat will work but how do you torque it?
I've never actually set a torque value to a ball joint. Just set them good and tight and then knock the locking plate over the face to keep it from moving.
Post by: MiniDave on July 16, 2024, 07:00:56 PM
I have a large 1 1/2" wrench as well as the deep well socket. Northern Tool has the sockets for reasonable $$$, I think I paid less than $10 for mine.
I also just tighten them "gutentite", then bend over the lock tabs in a couple of places. I've never the nut loosen up.
Post by: 94touring on July 17, 2024, 07:23:49 AM
Another thing worth noting. I noticed on these ball joints, compared to others in my stash of older parts, is they are more pointy on the ball end.  The reason for me removing this particular ball joint was noticeable slop / up and down play.  Considering it only has maybe 750 miles on it, I wonder if the pointy-ness of the ball has something to do with that.  I only had to remove the slimmest of shims and the friction and play on the ball joint was back within spec, which is moves with a little friction by hand with a glove on. I'll just have to keep an eye on them and see.  Japan mini has some regular ball joints that are high quality like mini would have had from the factory which are NLA.  They also have those pricier no shimming required ball joints.  If these continue to wear abnormally, I may end up buying a set of those.
Post by: MiniDave on July 17, 2024, 10:06:19 AM
I'm planning to run those on my hot rod for sure......the no maintenance ones that is.
Post by: joakwin on May 04, 2026, 05:48:30 AM
I have a set of the ball joints from Japan, they are super nice, been on the car for a few years now, pricey but worth it
