Just changed out my pads on the front of my 05 S. The sensor came on the other day and I knew it was about time to change them out anyways. Got the pads today, took about 30 minutes after fumbling around a little on the front left. However, I learned that once your sensor comes on, you have to buy a new sensor! Wish I knew this when I ordered the parts. I guess when I do the rears I'll buy the sensor to get the blasted light to go off.
You have to reset the light to have it go out, AND buy a new sensor and wire harness. The instructions on resetting the light are on the BINI forum and you may not need to replace the sensor if you don't care to have the warning light (just leave it off).
I found a front and rear set of sensors and wiring on fleabay for around $12.
dan
I was just reading I can splice the wires to make it go off too.
